LED Turn Signals
its something to do with the the fact that they are LED, the resistance is different. There is a way to correct it, I'm just not sure exactly what it is, its something with adding a resistor somewhere, just not sure where
I ran into the same problem.
The chassis electronics load tests the circuits when the lights are on.
The symptom for you is that both turn signals illuminate when the lights are on, yet they flash fine.
Unfortunately, even with an LED flasher, it stills stay on, so you have to get a load resistor. The chassis sends a voltage to see if there is a load, then kills the voltage.
Otherwise, there's a constant 13.4 volts across the terminals when there is no incandescent lamp there, and the LED does not draw a high enough of a load.
I got this for the fix:
http://www.v-leds.com/BlinkerWarning...-p5679822.html
