Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
drop it like its hot (lowered V)
Old 06-01-2011, 03:42 AM
jj_z28's Avatar
Default drop it like its hot (lowered V)
Cut 1 1/4 off front coils and 1 1/2 off back. Used MM spacer. Running 275s out back with a lil rubbage. Nothing major and the lip is rolled
Old 06-01-2011, 07:43 AM
Ekshail's Avatar
How is the ride quality after cutting the springs?
Old 06-01-2011, 11:49 AM
jj_z28's Avatar
Rides a Lil stiffer but not bad at all. Fronts a little bouncy which I don't like but can live with.
Old 06-01-2011, 11:50 AM
Skidmarcx's Avatar
Looks nice!
Old 06-01-2011, 12:43 PM
ferny's Avatar
cut the bump stop a bit more and it might be less bouncy.
now go lower!!! lol..jk
lookin good bro
Old 06-01-2011, 12:53 PM
EasyZ06's Avatar
Looks really good with the big tire out back!
Old 06-01-2011, 01:51 PM
jj_z28's Avatar
Never trimmed the front bump stop. Pretty sure its hitting. Just rides like a typical cut spring. LOL.
I would luv to go lower. Might sell the 275s And put the 245s out back and go with some 225s in front. Maybe go a Lil lower then. : )
Old 06-01-2011, 10:15 PM
shadyLS6's Avatar
great ride height.. those MM spacers are money
Old 06-02-2011, 12:43 PM
ferny's Avatar
i had cut mine in half and the bumpyness went away. front and rear bumpstops
Old 06-02-2011, 01:42 PM
-M-
-M-'s Avatar
Good luck with that, OP. I only say that because some things are worth doing right the first time. Oh, and your bouncing because you changed the spring rates and I bet their cut to an open position, not ground closed like springs need to be.
Old 06-02-2011, 03:34 PM
lupers3's Avatar
Holy crap thats terrible
Old 06-03-2011, 04:23 AM
jj_z28's Avatar
I've cut springs and heated springs with no issues like u show. Not saying That it wont happen this time but I realize its the "wrong" way. Its not a permanent thing And they dont make a spring for the height I want. And coil overs are out of my budget at the moment. But hopefully nothing like u posted happens. I know it can.
Old 06-03-2011, 02:50 PM
EdmundGTP's Avatar
The height of your car in the pics posted above is damn near identical to the ride height of the H&R springs.... Just sayin..
Old 06-04-2011, 01:41 AM
jj_z28's Avatar
H&R are close but I'm going lower as soon as I sell the 275s. Or just end up going with h&r cuz there is no way I'm tracking my car with the current springs. Hahah.
Old 06-04-2011, 01:56 AM
wcryan's Avatar
U still get a little stinkbug with the H&R though
Old 06-04-2011, 10:04 PM
MIGHTYMOUSE's Avatar
nice job jj. looks to me like you did it the right way i agree you may be bumping the stop, but it will surely be oversprung compared to stock.. no more oversprung than any other name brand stiffer lowering spring .... lots cheaper tho!
Old 06-07-2011, 12:51 AM
Hmbre97's Avatar
Do these cars have progressive or linear rate spring?
Old 06-07-2011, 02:07 AM
JJSimon904's Avatar
I'm not a fan of cutting springs either, but you did achieve the perfect height IMO!
Old 06-10-2011, 01:32 AM
wes8398's Avatar
I recently installed H&R springs and MM spacers on my V, and it's lower than what you've got there... In the rear for sure. If you're uncomfortable cutting more spring, and you're cool spending $250, I think you'd be happy with the h&r drop.
Also related to your post, I just put Linea corse Venettos on my car today with 275/35-19 tires out back. Unfortunately they're rubbing on the fenders with big dips in the road and also rubbing on the passenger side rear trailing arm on left hand turns. So I've got some work to do to fix that. Any suggestions?
Front:
Rear:
Old 06-10-2011, 02:05 AM
btownws6's Avatar
looks good
Quick Reply: drop it like its hot (lowered V)
