CTS-V dynoed
ok... so instead of raising the BS flag.. what's yours dyno at and what's it run in the 1/4?
and fwiw my car weighs in at 3900 w/me in it... (F-body) ... I ran 12.9 w/a lid and stock tires...
Originally Posted by cvp33
I've read the articles in C&D, MT and R&T. My statement still stands. Someone explain to me how a 3900 lb. car can hit those numbers with IRS and runflats while generating only 318 rwhp. It simply can't be done.
Road and Track also has it hitting 100mph in 11.4 secs. That's on par with the following cars:
Car - 0 to 100mph - Horsepower
Vanquish - 10.8 secs - 460
M5 - 11.3 secs - 394
Ferrari 550 - 11.1 secs - 485
S-Type R - 13.0 secs - 390
Maserati Coupe - 11.4 secs - 390
These cars all have similar girth and I doubt highly that their horsepower ratings have been inflated. I also doubt highly that GM could engineer a vehicle capable of this performance with only 318 rwhp. If they could, just imagine what all the stock Z's would do with solid axles and radials.
My BS flag stands.
My BS flag stands.
i have to agree with cvp33, 11 sec is quick for a car to 100mph. Unless the suspension and aerodynamics are incredibly efficient, and keep in mind this car is not the most aerodynamic car (anyone know the Cd of the car?). It's basically a 3900lb box, and this takes alot of power to get up to speed.
BS flag?
Why in the world would they BS about dyno numbers? My formula bone stock dynoed 280-288 rwhp. I went to the track the next day, and ran a whole handfull of low 13 sec runs,all but two being under 13.4. My car weighed in at 3700(+) with me in the car, and it was end of august ..and like almost 100 degrees at the track.
So this car...dynoes a little more, (probably has better heads than my ls1 heads at the time )...weighs more, and has comparable track times.... whats not to believe... more power offset by more weight.
Larry
Larry
I don't dispute that a car with 318 rwhp can do the quarter mile in 13.4. But it definitely can't do it when it weighs 4,070 as tested, has IRS, GoodYear Runflats and will NEVER reach 109 MPH by the end of the quarter with only 318 ponies. Physically CAN'T be done.
The car has a M12 gear box with more aggresive gearing than an F-Body, a ton more area under the curve than an M5, and a motor with a sweet spot in the RPM band for drag racing. Also weight has less to do with trap speed than it does ET. Look at the old Impala SS LT1. They typically trapped nearly the same as an LT1 F-Bod despite being significantly heavier.
Typically high MPH comes from power, and good ETs come from low weight and traction.
-Adam
Impala trapping as high as an Fbody.
Originally Posted by Adam Bruce
Uhm, why not?
-Adam
-Adam
LT1 Impala SS's were ~90mph cars through the 1/4.
Also, up at Great Lakes Dragstrip, a guy has brought his M5 out, and it ran 12.8@108mph as it came from the factory.
Everybody likes to think the LS6 has such a better torque/power curve, but 12.8@108 in an M5 doesn't lie. It makes some serious power to do that.
Mike
#33
I really couldn't care any less what this would do in a quarter. It's more than capable of doing 12's. There's absolutely no way I would spend the decent sum that this fine automobile costs and totally ruin it for anything but a contest of acceleration. As far as the aftermarket is concerned, the quality on their parts with of course the expected fashionable pricing, better be top notch, and not like the garbage they tried to pull over on the last F-body owner. If I were to buy a car of that caliber, I'd damn sure expect quality in line with the car. I suspect that it will be the same old bs. ( an assload for a cam; an assload for a head porting job, too much for air cleaners, pushing products that don't work, etc.) If I had a CTS-V, there's absolutely no way I'd take it to one of the jerk-off fly by night speed shop parts peddlers. If the car is to have any justice, it's going to have to be promoted to a crowd that cares about more than stupid trap speeds or quater mile times.
#34
Originally Posted by mgreen
OMG, that's crazy! Impala SS's NEVER trapped 98-102mph stock (which is what an LT1 fbod does)! I think the highest a stock Impala SS would trap was ~94mph. And that was on a good day. And BTW, trapspeed is directly proportional to weight. I don't see how it's affected less than ET.
Mike
Mike
Trust me, there are two things I know, M5s and LS motors, and the LS6 is a much more rounded motor. The M5 V8 lacks low end punch big time.
-Adam
#35
You must not spend much time at the track do you? ET is more deeply affected by weight as the first 60' of travel the car has the most inertia to overcome. Dropping weight shows much higher gain in the form of Lower ETs. Why do you think Motorcycles Get such fantastic ETs with such low MPH? My Bike does high tens in the low 120s.
the LT1 Impala SS was a mid to low 90mph car, the LT1 Z28 was a mid to high 90 mph Car (Yes the SS could crack 100 mph, but the RWHP of the Impala is more comparable tothe Z28). As you can see the 600 pound weight difference was only a couple MPH spread, it WAS however a huge spread in ET. Weight does affect both ET and MPH, it just has more of an affect on ET than it does MPH.
Mike, here is a picture of my Garage, know what that car in the background is?
-Adam
-Adam
I consider the bottom end for an LT1 Fbody to be 96mph. And the bottom end for the Impala SS to be ~89-90mph.
Which is almost right on for the 600lb difference. The general rule of thumb is every 100lb = 1mph difference.
BTW, I'm 8 minutes away from www.Route66raceway.com , believe me, I have PLENTY of experience at the dragstrip.
You may know LS6 and M5 motors. . . but have you driven a CTS-V to see what the LS6 feels like in that particular car?
Heck, an M5 motor would probably feel like it has a lot better low end punch if it was in a 3300lb Fbody.
My car goes 12.0@117mph (soft launch w/ 4.10's, 3485lb raceweight).
But with a full tank, crap in the hatch area, and a 230lb passenger, I'd say my car feels like it lacks on the bottom end.
#36
I still disagree w/ you Adam. Sorry. I've seen stock 2.73 geared LT1's hit 101mph in the 1/4 in 70* weather (nothing fantastic). . .
Well, I don't see a picture of a CTS-V there. . .
PS my Motorcycle only makes 7 more MPH than your Car but it's a 1.3 Seconds faster. Yet If we did a street race from 60 mph I know (from experience) you would have a much better time keeping up. Weight is much less of an issue once you get moving.
-Adam
#38
If memory serves correctly, the intake and exhaust manifolds are pretty restrictive.
The intake does a 90 degree turn and one of the rear primaries on the exhaust manifold is pretty restrictive as well.
40rwhp from headers and exhaust? Maybe if you use a plasma cutter and do some creative bodywork to get the headers to fit?
#39
I found this site with the help of GNSCOTT from the Caddy forum.
http://www.corral.net/tech/horsepower.html
Simply plug in the weight of the vehicle as tested - 4,070lbs. in the case of R&T's CTS-V
Your desired trap speed - 109mph in R&T as well.
This equates to 420 hp needed to propel the vehicle to the top end.
FYI
FYI
#40
to whoever said they wouldn't put crap aftermarket in a CTS-V. . . uhhh. . .great. but an ls6 is an ls6 is an ls6. . . so i'm thinkin the same cams that fit in a z06 will fit in a cts-v. doesn't lunati make some? i wouldn't call that crap. i know the heads gotta be the same. . . god, those patriot heads are terrible too. . . i would buy a porsches and put aftermarket stuff on it if i had the money and there was an aftermarket. if you wanna make your car fast- you wanna make it fast, regardless of how much the car costs.
