H&R's lowered rear too much ...
#84
In a new thread, or here Mighty? lol
I'll drive it for a few days and report back. Initial impression is that it's about the same, but that was just a 5 minute test drive around the block.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#86
I drove around town quite a bit today and I can't say I noticed much change in how the cut OEM springs feel compared to when I had the H&R's in there. It would definitely still be my preference to use the H&R springs if we can find a spacer of some sort like you're working on. Keep us posted on how the progress on that goes! I'm not much of a fabricator, but I'm keeping an eye out for things that might work.
#87
A follow up on yesterday's comments. Today I had a lot of running around to do, so I was out on the streets/highways for almost the whole afternoon. I retract my statement that I don't feel much of a difference with the cut oem springs from the h&r's. There's definitely a difference. The *** end feels a bit loose and waggly or saggy or something like that. It's real hard to describe, but I definitely feel it and I don't particularly like it. Trying to think of a way to space up the lower spring mount like you've mentioned. I'm thinking something like a hockey puck, but a bit bigger diameter. I haven't looked at the lower perch much to see what else would have to be done to make something like that fit, but there's gotta be something.
#88
In the event that someone's using the search function on this site, I thought I'd update this thread real quick. It's just a cut n paste from another similar thread, but I want the answers available for anyone who's having similar issues.
After trailing arms and the soon-to-be-known 'edmod' (3/8 rubber homemade 'washer' under rear spring perches to boost up the 'too low' H&R's), everything is awesome! No more 'reverse rake', no more fender rubbing on tires, no more wheels rubbing on trailing arms, and no more crappy feeling cut OEM springs.
![](http://i779.photobucket.com/albums/yy71/wes8398/d5e83c0e.jpg)
![](http://i779.photobucket.com/albums/yy71/wes8398/20a714d7.jpg)
![](http://i779.photobucket.com/albums/yy71/wes8398/2c00654f.jpg)
![](http://i779.photobucket.com/albums/yy71/wes8398/e6973662.jpg)
![](http://i779.photobucket.com/albums/yy71/wes8398/abb610e5.jpg)
![](http://i779.photobucket.com/albums/yy71/wes8398/397b54c6.jpg)
#90
I can only hazard a guess that it was factory tolerances and/or the OEM bushings that caused that issue. Passenger side rubbed when turning left, driver side when turning right. The more force in the turn, the more severe the rubbing.
