Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Trunk mounted meth tank (pics)
Old 07-20-2011, 02:44 PM
tommycompton's Avatar
Default Trunk mounted meth tank (pics)
Got as far as mounting my tank in the trunk. I had a buddy weld bolt studs in the spare tire well to mount the tank bracket instead of making holes through the floor. I used a 4" toilet flange to make the splash guard under the trunk lid, and a rubber adapter. Just grabbed a fuel door from NAPA to make it all look clean, and that way I don't have to remove the spare lid every time I fill it.
I have yet to hook up the braded lines and electrical, but I was thinking of running my boost-a-pump and meth off of the same switch seeing as they both will be set at 5 psi.
I was also thinking of doing my spare lid out of checker plate eventually.
Anyway here are some pics.
Old 07-20-2011, 03:52 PM
1BADCTS's Avatar
Looks good Tommy. As sh*itty as it sounds (ha ha, get it?) I may have to steal that toilet flange and fuel door idea to use on mine. I still need to run the boost reference hose from the controller in the ashtray, to the motor, then I'll be done.
Done is a relative term of course... Given I'm still waiting on the FREAKING SUPERCHARGER to come back...
Old 07-20-2011, 04:25 PM
wcryan's Avatar
do they have bigger tanks than that?
Old 07-20-2011, 08:02 PM
I just went to home depot looking for pvc pipe and saw the toilette flange and figured it would work even better. Just trimmed it down then used the rubber adapter to get the desired depth for it to rest right on top of the tank. I'm sure you could find a used flange for a reasonable price, lol.
I'm sure you could use a full size fuel cell if ya really wanted, but considering a washer fluid size container generally last a couple weeks, I'm sure 3 gal should be enough.
I went with alcohol injection systems set up because I liked the tank, and that they have braided lines as an option.
Old 07-20-2011, 08:08 PM
wcryan's Avatar
what did ur whole meth kit setup run you?
Old 07-20-2011, 08:12 PM
I think it was like around 500.00
Old 07-20-2011, 08:17 PM
wcryan's Avatar
: O....... That's not much
Old 07-21-2011, 07:54 AM
Is that sarcasm? lol
Old 07-21-2011, 10:38 AM
Squid4life's Avatar
Who's kit are you running? That is a nice clean install, nice work!
Old 07-21-2011, 03:20 PM
http://www.alcoholinjectionsystems.com/index.html
Old 07-21-2011, 04:51 PM
wcryan's Avatar
no, not sarcasm. I thought they were more expensive; so I was actually suprised. Sorry this may sound stupid, but where do u get meth from? I know it's not from "tweakers", haha
Old 07-21-2011, 05:54 PM
Most places that sell paint, hardware stores, walmart, will sell it by the gallon. You can even use windshield washer fluid (that contain methanol) usually 40% and top it up with heet gas line antifreeze to get a 50% mix.
Old 07-21-2011, 07:56 PM
wcryan's Avatar
what kinda gains do u get?
Old 07-21-2011, 11:32 PM
Squid4life's Avatar
Originally Posted by tommycompton
Cool, thanks for the link. I use Alkycontrol PAC alky on my GN so was curious.
You can also buy it in a 5 gal cans from I think VP, wherever they sell race fuel. I forget how mush $ it was, been so long since I bought it. I run VP M1 Methanol. Probably overpriced though...
Old 07-21-2011, 11:40 PM
itsslow98's Avatar
Yea my brother has an alkycontrol kit on his GN and its top notch. He also uses VP straight meth with very good results. For as much as you use its worth it to use the best stuff.
Old 07-30-2011, 02:41 PM
Wired and hose now run to the front. I used an adapter and a short braided line so I could make a connection through the trunk wall.
Nozzles hooked up to the blower intake pipe.
Instead of a bunch of Tees, I rigged up this boost reference distribution block, has a line for my meth switch, BAP switch and one for a boost guage.
I'll mount it to the firewall.
Old 07-30-2011, 03:43 PM
1BADCTS's Avatar
Hey, I like the distribution block. That's a nice setup.
Old 07-30-2011, 04:55 PM
Thanks man,
You can buy some online usually 40+ dollars plus shipping. I just went to hardwarestore where they sell air compressors/air tools and found this one. I had to drill and re-tap the ends to 1/8 Npt, because they were smaller than I needed for the BAP and Meth switch. Total cost $10.00 including a plug and both barb fittings. The blue even matches my AN fittings
Old 07-31-2011, 06:46 AM
lubelizard's Avatar
Good to see you knew the distribution block trick. Harbor Freight has them as well, very cheap and very useful.
Quick Reply: Trunk mounted meth tank (pics)
