Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Spring and spacer install...
Old 08-20-2011, 12:20 PM
guitar333's Avatar
Default Spring and spacer install...
Will someone send me the MM spacer instructions please..?
guitar333ATgmail.com
That would be awesome.
I am putting my new brakes and springs on.
Do I remove the shock/spring as an assembly then use a spring compressor to remove - on both front and rear?
Old 08-21-2011, 01:50 AM
RRsV's Avatar
This should help.....
http://www.cadillacfaq.com/faq/answe...all/index.html
I bought some MM spacers and have them somewhere...if you still need the instructions I can scan / email them to you if the link above doesnt help.
Old 08-21-2011, 01:59 PM
wes8398's Avatar
Guitar - that FAQ link is all you'll need to install the springs. The front are struts (remove as assembly, need compressor) and ther rears are shocks (springs are separate).
Old 08-21-2011, 08:43 PM
guitar333's Avatar
Thanks! I figured it out. Surprised how much easier than my other cars this was.
Still need to install my powdercoated calipers and SS brake lines.
Anyways, here's a few pics..
Old 08-21-2011, 08:47 PM
guitar333's Avatar
BEFORE:
Old 08-21-2011, 10:42 PM
RRsV's Avatar
Originally Posted by guitar333
NICE!! Did you install the Z06 end links too?
Old 08-22-2011, 12:02 AM
guitar333's Avatar
No! I was expecting them before the weekend so I could install them, but they didn't make it in time. I will have to put those on later this week.
Old 08-22-2011, 12:56 AM
BUKSING's Avatar
Looks good. What springs did you go with? H&R?
Old 08-22-2011, 06:08 PM
RRsV's Avatar
I just bought a used set of H&R springs myself. Cant wait to get them on....Im not sure if Im going w/ the Z06 or the adjustable end links???
Are you not using any endlinks or are you using your stockers until the Z06s come in?
Old 08-22-2011, 06:20 PM
guitar333's Avatar
I'm using the stock endlinks with my H&R's right now. Ill get the Z06 ones on there when they arrive tomorrow.
Old 08-22-2011, 06:30 PM
RRsV's Avatar
Cool....well again nice job, it looks great!
Old 08-22-2011, 08:39 PM
06blackonblackctsv's Avatar
Looks great, but is your front grill on good? Looks like its poking out a little, or maybe im seeing things.
Old 08-22-2011, 10:55 PM
guitar333's Avatar
Yes, it was popped out a bit. That was before my trip to the store to buy some clips after I painted it.
Old 08-29-2011, 11:56 PM
RRsV's Avatar
Were those the right Z06 links you ordered? My springs came today, I'm going to try and put them on this weekend.
Old 08-30-2011, 07:57 AM
wes8398's Avatar
Don't be surprised when the links give you some trouble. They're a PITA and require some patience and/or beer. Just the right amount of load on the suspension (done via floor jack under A arm) will line things up to get the old ones out, then you'll have to find the happy spot again to get things lined up for the new links. Drilling the holes out STRAIGHT is very important. I killed 2 drill batteries doing it with a crappy bit. A good bit and a decent cordless drill would do you well. I have a thread or two on this topic that you'd find useful. Just search my posts.
Old 08-30-2011, 09:19 AM
RRsV's Avatar
What makes these so hard...Ive read several lowering threads where people complained about installing them. I HATE PITA stuff, especially something as simple as a little end link that should take 2 mins to swap out!!!
Old 08-30-2011, 09:45 AM
wes8398's Avatar
You'll see. Took me about half an hour of dickin' around per side.
Old 08-30-2011, 10:07 AM
Eastern Regional Coordinator
CTSVBiggie's Avatar
What plate bracket is that... Not too hateful and I need a solution that doesnt include drilling holes.
Old 08-30-2011, 10:10 AM
guitar333's Avatar
It's the one Creative Steel sells. Just over $100 powdercoated black. Makes you legit and beats drilling holes...
Old 08-30-2011, 10:14 AM
CTSVBiggie's Avatar
I wont drill holes... but 100 god dayum..
Quick Reply: Spring and spacer install...
