H&R Springs/ WHAT camber adjustment for the street are you using?
#43
No man, I already knew every car would be different and I previously stated that. You also think you know what I am allowed to ask which your not. And your not to decide if I should be here or not. I can get my answer from the few who are willing to answer my questions. I am ok with that. I didnt come here to make friends. This forum has always been typically filled with a select few like you, and thats ok.
#44
Some peeps think comparing other setups, no matter how different they are is useless but its not. I like to compare and it helps now and in the past especially if I decide to mod further. This is what the forum is all about: INFORMATION. Not peeps telling each other what they think they need to know. If I wanted the info I didnt ask for, I woulda asked that question in a different thread or did a search.
#45
What camber adjustment are you all running for the street with your H&R springs? My GM Service Manual states that "stock" the rear should be -1.4 and the front should be -.5
My rear camber now is -4 and the front is -2
I messed with the rear a little and it looks to me like all of the camber can be adjusted out.
If you want some other suggested numbers, try the CTS-V FAQ.
![Nono](https://ls1tech.com/forums/images/smilies2/nono.gif)
Oh, and remember, kids, when your (
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#46
Hello all! (Gives the finger to 9t8z28) I just installed h&r springs on my v and am loving it. The questions I had about them all of you guys answered, I wanted to express my appreciation for you guys in the forum, you guys are always very helpful!
Oh and 9t8z28 go buy a BMW so u can be with the rest of your stuck up a-hole kind
#47
Oh and 9t8z28 go buy a BMW so u can be with the rest of your stuck up a-hole kind![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#48
Just playing devil's advocate here, but if "all" cars are so very different then why/how could the factory put out stock alignment specs?
Everyone on here tells the OP that "every car and spring is different, so just go get a stock alignment and call it a day"......kind of contradicting.
Now i understand that the factory spec is the most ideal for street use, but the OP may want to give it a shot in his driveway, or at the very least check to see how far outside the spec it is.
2007, 2753519, adjust, adjustment, adjustments, cadillac, camber, car, cts, ctsv, fuckingwetvagina, legit, miami, pic, vredestein
