rear broke
In other words, the dealership can't rebuild it, they can only replace it.
I'll try to remember to check my receipts at home, but I paid over $2k (parts and labor) to get a new diff through Lindsay. I know they gave me one estimate, and then I told the service writer, "Oh, I'm getting parts through Luke," and the estimate dropped by ~$700.
I talked to Luke at Lindsay Cadillac and the replacement cost 1600. I am trying to find some with a trail so i can get my car to a friends house that has all the equipment to open her up and see whats really broken...
If I go with the partial creative steel kit??? will this rear fit in it? granted its 3.73 ratio
http://www.ebay.com/itm/Ford-8-8-Alu...item231910b168
I am not aware of any "repairs" that have been possible on the diff.
I was thinking the case is cracked but no fluids anywhere... I started her up this morning and put her in gear and slight grind and she tries to move... gotta get her to my buddies this weekend to tear her down and find out what is broken and what need to be done before i go any further. Found out it might be a shaft broken from one of the axles or the spider gear in the diff... could be any of those. gotta tear her down and see. i will keep you guys in the loop... hoping its just an axle... cross ur fingers!
diff.
where in Md. are u located?? and does your friend with the lift, is he a good mechanic.....and able to help u do the labor?? I might be able to help u with an 06 complete rear and axles,etc.. for i am about to jump off the fence onto a CS or G Force build....My rear diff and axles have exactly 30k miles of which 4k are from burnouts from previous owner...lol
#34
If there is no fluid spilling everywhere and it tries to move when you put it in gear, you more than likely broke off the axle stub inside the diff. Don't try to drive it any more, the diff is probably salvageable but there will be metal bits in the gear oil which can cause damage.
Remove the diff, pull off the side cover and get the broken axle stub and metal pieces out of the case. Buy a new axle shaft (much cheaper than a diff) and reinstall.
Good luck.
Good luck.
#35
#36
Cadzila's Banned Troll Account
#37
I live in Southern Maryland not to far from Andrews Air Force base. Yes sir my buddy has all the required tools and from what i hear is a pretty good wrench turner! His V is maggied and he did all the work himself including the tune......lol. The more hands and help the faster i am back on the road since its 60+ degree's again today!!
#38
Thats sounds like it... No fluid, no nothing... Positive traction rear ends just spin if the diff cant grab both shafts correct? Thanks for the info bro!! I'm new back to the American scene... I have JDM muscle also but what fluids do you guys run in the diff's? Everything in my JDM's are Motul... What do you guyz run in the V's?
Good luck.
Good luck.
#40
Guys have also broken the outside stub near the wheel bearings, but I think when they let go the axle shaft usually thrashes around on the rear suspension and its very obvious what broke. And breaking the outside stub seems less common.
I broke an axle about a year ago and my brother posted a pic of it, which turned into a thread of everyone showing their broken axles too, lol.
https://ls1tech.com/forums/cadillac-...diff-weak.html
