OUT with a Spec - IN with a Monster
Let me first start off by saying I've had fairly decent luck with Specs products in other cars. I've installed them in tons of F-bodies and Corvettes without any issue other than the common need for shims and/or an adjustable master.
The short and (very) sweet version:
A 2004 CTS-V was dropped off for a clutch install on Nov. 28th. Per my recommendation he ordered a Spec Stg 2 designed for the CTS-V. Fast forward through 6 transmission R&R's, and 1 trip back to Spec on our dime in which they said "it's fine" I decided to hang it up with Spec and we ordered a Monster Stage 2 kit designed for the CTS-V with the modified LS7 slave.
Funny thing. Engagement is now like a razor blade cutting through hot butter on the first shift (rarity on Cadillacs), driveability is perfect, and we didn't have to remove the transmission 6 times trying to make it work. After speaking with (Steve I think?) over at Monster, I think I'll be shifting all my business over to them from now on. This Monster has been GREAT in this car, and I've always had good luck with previous Monster kits.
If you're looking for a good clutch that won't break the bank and works on the first try without the need for shims or a $300+ adjustable master, check out Monsters stuff. They saved the day on this situation after spending over a month trying to make another product (that obviously wasn't going to) work.
Cheers.
Cheers.
I just can not slip the Monster enough to get a proper launch, and that is from a stop sign, not racing.
The pitts if stopped on a hill.
The chatter would literally rattle a filling loose.
I ended up with red spots on the floor from the trans fluid that was shaken out.
One thing the Monster doesn't do and that is slip.
You must not have had that SPEC installed correctly! Either that or you have a hydro problem. See these types of issues are usually caused by fluid transfer issues (sarcasm and general BS spewn out my ***)
I'm very happy with my Exedy twin. Had the same issue with a spec 3. They said hydraulic problem. I installed an Exedy twin, all my problems went away instantly and never came back using the same hydros I used with the spec.
I heard just the opposite.
I'm not sure what disk material you're using, but some materials will chatter more than others. I'm not some Monster cheerleader but I can say for sure I've never had a Monster clutch chatter and I've used 15-20 of them over the past 2 years. You could possibly have a bent disk. See that a lot when people use the bolts to pull the trans in the rest of the way if it isn't falling straight in the hole. If you're using a Stage 2, I'd replace the disk first before spending the $ on a twin disk. I think you've got a bent disk.
You must not have had that SPEC installed correctly! Either that or you have a hydro problem. See these types of issues are usually caused by fluid transfer issues (sarcasm and general BS spewn out my aas)
I'll agree with ya.
It ended up not being a good idea in that it didn't work out.
I know one guy replaced the puck disc with a full disc (from Monster) and that "fixed it".
I decided to replace the whole thing.
It doesn't matter whether it is a DD or a racer, if you can't get a good launch, it sucks.
Damian, what would cause a Monster clutch to chatter? Besides the bent disc. I have a friend with a monster 3 in a GTO, it chatters pretty bad. Could his driving style be causing it? Or is that just how a puck type clutch acts? Just trying to decide what to go with next.
Back on topic, Good work with the V. Ill be giving you a call in the next few months for a tune.
I don't think I've ever installed a Stg 3 from Monster so I can't comment for sure on how it "should" or "shouldn't" drive.
Aside from a possible bent disk it could just be the clutch material. Has he called Monster about it yet? Any time I've ever talked to the guys down there they've always been knowledgeable and helpful.
The spec 3 I had was a puck style and it chattered pretty bad too. My Exedy twin is so smooth it like driving a stock clutch, without all the hydraulic problems! No lie! If your looking for a twin that locks up good and is smooth, try an Exedy! I have talked a few people into getting one after I installed mine and they will tell you the same thing. I'm honestly not sure I will ever use anything besides Exedy now. They are expensive, but they sure make life easy after you install it.
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
Don't derail my thread with smart *** remarks, thanks.
