Best header gaskets for 1 7/8 kooks?
Kooks are in the mail and I want to order the best header gaskets I can get. What have you guys used that seals good and will clear the 1 7/8?
Thanks
Dave
Thanks
Dave
Kooks Gaskets
+1 on the GM gaskets (with some qualification as follows)!
The GM pickup gaskets have round ports that are large enough for a 1 7/8" pipe and will seal better than the oval port gasket type found on other models.
If you have the D-port 1 7/8" Kooks, use the stock LS7 Y-car gaskets.
Instead of the Kooks-supplied bolts, use new GM bolts, the type with the green threadlock on the threads, and follow the factory torque sequence and they won't loosen.
Mine had no leaks when installed or since, and they've been on the car since the summer of 2006.
FelPro gasket at Advance and they're only 11 bucks.
FWIW, you're best to do plugs and wires while the exhaust manifolds are off. You're likely gonna break more than one plug taking them off.
throw plugs and wires in, type in VISA as your coupon code for 50 off of 150, or BIG30 for 30 off of 75, or P20 for 20 percent off your entire order.
But I agree, if the plugs are old its a good time to replace em.
