Group Buy Opportunity: Extreme Composites Hood
It could also be the bumper fitment. If you notice the gap is larger under the headlight to the bumper on the side of the hood that there is a larger gap. In both cases it doesn't appear to be the hoods fault.
Also, I had some issues with the gap on of the fender running the length of the hood.
I'm not sure how to address the issue either. I've had my bumper off 3 times already.
Guys ....!! That's not a hood fit issue, It's a bumper fit issue. The hood is fine.
Do to all the behind the scenes work on the intercooler, piping, ect. There just isn't enough space to get it back to fit right. Got tired of screwing with it & just said F***k it .
They forgot to install the intercooler in my ride, but my different manufacturer hood LOOKS identical in the same spot. It's probably more related to the factory variances (see trailing arm rubs on passenger side only w/wider wheels, etc).
They forgot your intercooler ?????
Now, Missing parts is gotta be covered under warranty .
#36
April 15th buy is starting to look eminent as we def have at least 4 so far I think. Fuzzy, never satisfied, branland, and myself....maybe denali and a few others. Cmon ppl only a few left and we can all get 150 off.
#39
#40
They said that the vents/rain trays do not come installed & that there's just a hole for them to be installed. Then it's up to the car owner/body shop how they want the vents installed. They can be "frenched" in with no seam, just dropped in, glued & go, or whatever. There is work to be done.
