Fog HID question
Fog HID question
Hey guys was wondering what exactly I need to buy and where to make that bottom fog light have some hids in it. I know most of you have already changed it out I just havent gotten to it yet.
Get the DDM H10 35w 4200k kit and a set of their brackets. You could skip the brackets and use strong double sided adhesive to affix the ballasts to the side of the fogs. You'll want to pick up 8 screw-on wire splicers from RadioShack. The whole thing should take you about an hour and a half from start to finish.
Eastern Regional Coordinator
I got the kits off of Amazon from xentec. Used em before and they are cheap as ****.
Working fine in mine(went 3500k but bought 6000k bulbs after not liking the color).
I have pictures somewhere.
that cheesy connector works. Just gotta go positive to positive. Was rather simple.
ALso did the low beams on my brothers 12 camry. And the kit for his fogs had a bad ballast so they sent me another overnight almost.
He went 8000k on both sets.
Here's what I bought:
https://ls1tech.com/forums/15939159-post6.html
Also, sticking double sided adhesive to the side of the fogs doesn't last. Both sides of mine fell & I need to reinstall one side because my wheel well liner is gone & it drug on the ground & pulled the connection. Luckily I heard the ballast drop & pulled over immediately. It's still usable, but all roughed up. I need some other method of mounting it. My fogs SHOWED a bracket in the ad, but didn't actually come with one.
This is the ballast (being installed) that drug on the ground. You can see it adhesived to the side of the bracket:
