Will the hsw nitrous plate work on fast 92 with 92mm tb?
Just agreed to a deal with another member here to swap my intake and tb plus cash for his fast 92 intake and 92mm tb. Just trying to get everything needed to get my car back up and running lined out so I can get it all.
Anyone know if the hsw plate made to work with the stock intake/tb will fit the 92 setup?
Ok. Intake has been trimmed already so it clears. I know I'll need to get a bigger rubber connector section to fit over the new tb and taper down slightly to fit the K&N intake tubing but that's not a big deal. Guess I'll have to look online for another plate to fit the new fast setup. Wishful thinking that the ls6 plate would fit it but I doubted it would.
Sweet! I was hoping for gains like that but wasn't sure if I'd get them being on stock heads. Eventually I wanna do some trick flow heads but for now, I'll be on the stock 243's.
Other than the new plate I'll need, will everything else plug and play? Injectors, etc?
The nitrous kit I have is NX and the only thing hsw is the plate itself. It has 4 lines going to it though as opposed to the one I saw online for the 92 that look like it has just 2 lines... One for fuel and one for nitrous. I should be able to find a 92 plate that will use the 4 existing lines I have right cause if not, I may have to sell this NX kit and go with the entire 92 kit brand new. That would suck. Lol
It's just one big NX box/module thing that has the wiring coming out of it and the two larger main lines going in from the bottle and the fuel rail and 4 smaller lines coming out of the front to the plate. 2 fuel and 2 nitrous on each side of the plate. I'll get a pic of it but I was told its a good kit.
Nevermind... I'm a retard. It's a Zex kit. Was looking for a pic to post to show u and I know mine is black and purple and finally found it and figured out i had it mixed up. Lol
Ok... After looking into it... Looks like the car has the ZEX kit #82235 that goes from 75-175hp but instead of using the little nozzle port that comes with the kit, my buddy bought the hsw plate for it instead which is actually better anyway IMO. Not really sure why the kit has 4 lines though instead of just two? Hmm... Must be some sort of advantage for them to do it that way I would think.
