Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Old 05-18-2016, 06:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
Is this a good cam for a mildly modified LS6
Old 04-11-2012, 05:08 AM
04LS6's Avatar
Default Is this a good cam for a mildly modified LS6
A used cam came up for sale which is local. Wondering what your thoughts are on the specs. My car will probably never get heads. Mods are OBX headers with cats, K&N cold air intake. I will most likely open up the intake with a fast 92 and 90mm throttlebody. Do you think this cam is any good for me?
I have a Comp camshaft with under 4000 miles on it.
Bought it for my 383 build but actually bought a kit off the forums that included another cam so I have no need for it anymore!
Cam is in mint condition and lightly used
asking 230 + shipping to the lower 48 states price negotiable.
specs are: 230/230 .591 lift and a 112 LSA
Here are the cam specs (cam card) as it is custom grinded
SERIAL # Y 6009 SPEC CARD # 031430 SPEC CARD INQUIRY BY SERIAL #
PART # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
CORE C54-11E CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE Special Grind
GRIND # LS1 3725R /3725R HR112.0
DURATION @ .050 INTAKE 230 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 230 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3480 EXHAUST 1.70
VALVE LIFT INTAKE .591 LOBE LIFT EXHAUST .3480
VALVE LIFT EXHAUST .591 LOBE SEPARATION 112.0
DURATION .006 INTAKE C/L 112.0
TAPPET LIFT INTAKE 279 CAM ADVANCE 0
TAPPET LIFT EXHAUST 279 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 3 JOURNAL DIAMETER STD 2.165
VALVE OPEN EXHAUST 47 RECOMMEND VALVE SPRINGS
VALVE CLOSED INTAKE 47 DEPARTMENT P
VALVE CLOSED EXHAUST 3 SPC INSTR FOR CUSTOMER
please pm me with any questions
fits ls family and lq 4 and 9
Would you guys even consider buying a used cam?
Thanks in advance
Old 04-11-2012, 06:51 AM
NeverSatisfied02's Avatar
Nothing wrong with buying a used cam if it came out of a problem free motor. That can would perform well though IMO. Only thing I see is that those specs are based on having 1.7 rockers. Our stock rockers are 1.6 which would make that can quite a bit smaller unless u spend the money to do 1.7 rockers at the time of install. Based on that alone, I'd pass and get a cam with the specs u want based on a 1.6 rocker. It'll be easier on the springs and cheaper overall.
Old 04-11-2012, 10:06 AM
01_SuperSlow's Avatar
^^ LS1/LS6/LS2/LS3 all come with 1.7 rockers from factory.
Old 04-11-2012, 10:14 AM
RADEoN's Avatar
that's what i thought too.
Old 04-11-2012, 11:01 AM
1.6 stock...
Old 04-11-2012, 11:11 AM
GulfM3's Avatar
Originally Posted by NeverSatisfied02
1.6 stock...
double check that,
I'm pretty sure ls1/2/6 and all the truck motors come with 1.7.
the LS7 is the oddball that comes with 1.8
Old 04-11-2012, 11:38 AM
Ahh... maybe i've been misinformed then. I was told 1.6 rockers come stock and the stock LS7 rockers are 1.7.
I apologize if im wrong.
Old 04-11-2012, 01:32 PM
Hey, at least you didn't start a thread about what 1.7 rockers you should buy to increase lift
Old 04-11-2012, 02:01 PM
Lol! True story...
Quick Reply: Is this a good cam for a mildly modified LS6
