Sparco seat install (PICS)
Once all of my major performance mods are done (read: engine and supercharger), I've got my eye on a set of Recaro Pole positions. The trick is going to be finding a great upholsterer--it has to be leather and Alcantara. D3 has a set that they sell, but they're charging $1600 a seat:
![](http://d3groupinc.com/wp-content/uploads/2012/10/IMG_5784.jpg)
![](http://d3groupinc.com/wp-content/uploads/2012/10/IMG_5795.jpg)
![](http://d3groupinc.com/wp-content/uploads/2012/10/D3-Legionnaire-Interior-3.jpg)
You guys might like this thread as a side study in installing seats.
http://www.m3post.com/forums/showthread.php?t=314742
I picked up some new Evo II US seats a week or so ago. I started to piece together the install with the universal seat frame. I won't be using the sliders either. Man those things are low when the side mount brackets are fastened directly to the universal seat base. I can barely see over the dash and I'm 5'11". You either need to get a set of side mount brackets with lots of vertical height adjustment or use the entire universal seat frame setup which includes not only the square frame but also a height adjustable block up set of rails which bolt to it. You then need to fasten the side mount brackets to that block up rail. I should be wrapping it up in a week or so. You can see a picture of the Sparco universal seat base http://www.racing-seats-usa.com/491.html
Check this out.
http://www.the370z.com/diy-section-d...light-fix.html
