Video Update: In the 10's
I was not at home to drive the car yesterday. But RPM MotorSports did me the honors of taking my V to the track for Dragging Rights in Fayetteville. They made 2 passes with it. The first was a 11.17 @ 128 mph and the second was a 10.96 @ 129 mph. From what I hear the track wasn't at its best and the tires broke loose both passes when it shifted into 2nd. I'm happy to finally be in the 10's. Now time to just start bringing the time down some more. For a full weight street/luxury sedan this says a lot about what kind of shop RPM is and what they are capable of.
Below is the few mods that have been done to the car. It still has a stock torque converter.
Performance Mods
Stock Supercharger
2.55 upper/9.17 lower pulley combo
Air Raid CAI
Cat Delete/Stock Exhaust Manifolds/Stainless Works Exhaust
ID850 injectors
RPM MotorSports custom grind cam
RPM Dual Pass Heat Exchanger
RPM Heat Exchanger Coolant Tank
RPM "Rated R" Tuning
Big Thanks go out to Ryan and the crew of RPM MotorSports.
http://www.youtube.com/watch?v=NFSjz...ature=youtu.be
Performance Mods
Stock Supercharger
Air Raid CAI
ID850 injectors
Should get the times down alot with a better prepped track... If your spinning shifting into 2nd you got alot more mph on top also. Whats the 60ft and 1000ft times and speed?
Good run!!
Good run!!
Thanks Chris, y'all have done a excellent job on the car buddy!
1.63 60' not sure about the 1000'
I'll try to get more info tomorrow.
Another video
http://www.youtube.com/watch?v=xsNxp...layer_embedded
Another video
610 rwhp and 622 rwtq
Thanks, running y'alls full 3" exaust from where the cats used to be to the tips. Just need to get y'alls new driverside tail pipe section where yall made the changes so it don't hang lower. I love y'alls exhaust system, sounds awesome. I will be installing your headers next.
A couple pics
A couple pics
