54s 05V Build thread
#109
Your just plowing through this build of yours...
I should have some updates to my progress. Front braces are done, and i finally got my hands on Oval Tubing...Add a little strategic reinforcement is key...
Hopefully i will also install side skirts...
Nice slotted discs...
#118
Liking the build 54!! Its coming along nicely!! I'm getting closer to the end as well. But you'll probably get there before me
#119
The trailing arms will be custom as well.
I originally had coilovers out back, but they(coils) are moved back to the stock location.
If need be, I am going to lean the shocks in a few more degrees as I REALLY want to run 325s......er......345s.....
I feel the same. When i do new wheels and tires i'm going with 18x8.5 front and 18x 9.5 rear forgstar f14 with 245/45 front and 275/40 rear pilot super sports. That way i get just enough traction while getting the most rotational losses. And having the same factory sidewall is great for comfort as well.
Throttle steer is not needed during a 1/4 mile.
I will be running 18x9 up front with stockISH sized tires.; 20x11" and 315.30.20s.....if things work out, then I will be running wider wheels and tires.
On the track; 18x9s with 27g Drag Radials.
When this is done along with my 8.8; the cars foundation will be ready fr more power and I promise it will not be boring.....
