Gears? 3.73 v. 3.55
maybe this will help...?
https://vimeo.com/42096122
Though I hate the ashtray gauges... i really need to change that.
woot... partial CS kit is on the way.. 4 weeks for DSS to fab up my drive shaft and axles.. i got the built outer CVs since i'm providing the diff
sounds like a leer jet
LOL, though, that does sound like fun...
Ls1 t56 pt88
Are 3.55 good for my setup I have a ls1 forged piston rods prc 243 fast 92mm pt88 cam motion cam 236/232 117+6 10.3.1 compression . Just want to know if 3.55 would be good for my setup and what tire size .
If your ultimate goal is lower drag times, a lower gear is what you'll want to use to get off the line faster. 3.55 would not be a good choice there. 4.10s or deeper is recommended. Tire height can be chosen to with a gear calculator to find the ideal gear & RPM you cross the 1/4mi finish line in. http://www.tremec.com/calculadora.php
If you do mixed daily driving in the car and also like to hot rod it a bit (clearly, based on your engine) a 3.73 is a good compromise of both low end and reasonable highway cruising RPMs.
If your car sees a majority of highway miles but you like accelerating through long sweeping curves and rarely do any actual racing, then a 3.55 is a good choice.
Your gearing choice has less to do with your engine and more to do with how you intend to use the car.
If you’re drag racing you need to figure out your trap speed and final gear. If a longer (3.55) rear can save you that last shift that can help your decision. A shorter gear (4.10) might help you accelerate quicker on paper but it could cause you to spin easier and also need an extra shift before you clear the traps
I've been very happy sticking with 3.73s in my setup with 28" tires. I've been 164mph in the 1/4 so far, going through the traps around 7400 rpm. I'm willing to spin it upwards of 8,000 before changing the gearing, we'll see if it wont go 170mph this year. I couldn't justify going to a 3.55 until making 1500whp or so.
#33
