Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
AC Delco or Optima
Old 06-10-2012, 12:08 PM
ronb01ws6's Avatar
Default AC Delco or Optima
Time to change out the battery but i heard optima batteries quality has gone down, is this true? I would like the optima because it has more cca and the red top matches my fuel rail covers Any input would be great. Thanks
Old 06-10-2012, 12:18 PM
heavymetals's Avatar
Check out the ODYSSEY batteries.
Old 06-10-2012, 12:42 PM
kl2onik's Avatar
neither both are overpriced, look at interstate megatrons they are cheaper and crank way more
Old 06-10-2012, 01:27 PM
Skidmarcx's Avatar
I went with an Interstate Megatron... Beast battery
Old 06-10-2012, 01:56 PM
Dmax/04V's Avatar
The only reason to buy optima is if you need to mount the battery in a precarious position, or if you need a high level of amperage in a smaller package.
Old 06-10-2012, 03:35 PM
Zexell's Avatar
Optima's quality plummeted after being bought out by another company, Johnson Coontrol IIRC.
Old 06-10-2012, 09:59 PM
itsslow98's Avatar
I run interstate in everything even my boat.
Old 06-11-2012, 11:55 AM
rjoffe's Avatar
Anyone have any more input on the Optima quality issues ? When Optima's came out they were really quite good, I did quite a bit of battery testing back in the day. Haven't really kept in touch with the current status (didn't even know they were purchased by Johnson Control).
Old 06-11-2012, 12:42 PM
ram59's Avatar
I've tried two Optima red tops and they both **** the bed within eighteen months, one on a daily driver and the other on a show car and kept on a trickle charger. I will never use them again. Went with Odyssey and couldn'nt be happier. They do cost, but my cars aren't cheap either.
Old 06-11-2012, 12:45 PM
NeverSatisfied02's Avatar
I'm a fan of the optima red tops. Ran a yellow top in my old truck with a huge audio system. Never had an issue with them. Red top in my old V and a red top in my current one too
Old 06-11-2012, 12:59 PM
Greed4Speed's Avatar
I'd stay away from Delco. The one in my Camaro got bloated and the one in my wife's Grand Am did the same except it cracked and started leaking. One was 5 and the other was 4 years old. I got 7 years out of the next battery (not a Delco), and no bloating or leak.
Old 06-11-2012, 02:10 PM
CamminV6's Avatar
My V had an Optima Red Top when I bought it, was in the car for 4 years based on the sticker. I put another red top in when it finally started to give out over the winter and haven't had any issues.
Old 06-11-2012, 02:19 PM
ronb01ws6's Avatar
Looks like the cheapest I can find the interstate for is 160 and delco 141. Both have the same cca. Optima is 177 with more cca. I would rather find a place on the internet that ships since I have the money in paypal already and it doesn't feel like I'm actually using my money that way. Anyone know where I can get one cheaper?
Old 06-11-2012, 03:43 PM
etcts-v's Avatar
I've had my Optima red top (paid $160) running in my car for 2 years with multiple full cycle discharges (stereo drain) and it's still running like a champ. I love Optima and will always stick with them, with that said I am a stereo guy so I have high crank and long run time needs.
I also have an Kinetik in the trunk running my amps which is linked through a relay. Both work together perfectly.
Old 06-11-2012, 04:07 PM
kyoytey1693's Avatar
I haven't had good luck with my red tops. My current one is 4 years old. It was about 1yr old when I bought it, so only 3 yrs to me. And it wont hold charge more than about 4 days w/o a battery tender. Previous red top in different car did the same thing. My delco lasted 6 years until the post just sheared off while sitting in the parking lot. Otherwise there was nothing wrong with it. I would go with whoever offers the best warranty plan.
Old 06-11-2012, 04:50 PM
rjoffe's Avatar
The first Red Tops I worked with was in '92 We used to get them by the pallet full. I grabbed one for my Jeep. I used it daily including off road till about '99. So that was 7 years before it got weak. If they are only lasting 4 years now then they have really lost allot.
Old 06-19-2012, 05:31 PM
gearhead68's Avatar
I just went with the Autozone Duralast 78 series ($99). It has a nice red top too. Can't see spending for the sealed optimas or the 101 series.
Old 06-19-2012, 07:02 PM
meatyCTS-V's Avatar
I used to run an (old) Optima in my Miata. Had it in there for something like 5-7 years? It's only now stopped holding a charge after not driving the car daily every day.
I once went in to work with it, accidentally left the accesories on in the Miata, (stereo, etc.), came back out 12 hours later, car started up just fine.
Not sure what to do, I have to get a new battery for it, and I'm still trying to decide if I should do another Optima in it or not.
-meaty
Old 06-19-2012, 07:41 PM
gearhead68's Avatar
I've had good luck with these Exide sealed units in my cars that sit for months. Sam's club used to have them for $99 but recently they are $149.
Old 06-19-2012, 07:54 PM
BackNBlue's Avatar
I've had an Optima in my TBSS for a couple years no issues and it sits sometimes a month or more between starts.
Quick Reply: AC Delco or Optima
