Spring rate question
I have the GC setup with the 500/550 springs. I also have a mixed shock arrangement with FE4 up front and FG2 in back because of a bad front shock and no single FG2 available at the time. To the previous owner it was probably fine, but for me it just seems too soft, sloppy, and too much body roll. The dampening feels even to me, but I know it's still kind of odd to have the different shocks. While there are many options as far as different springs, shocks, sway bars, etc.. I'm unsure which to tackle first. From what ive read the hotchkis kit is worth getting, but that only solves body roll. I was looking at maybe going with a 600/650 setup, but I'm wondering if it will affect weight distribution and traction under heavy acceleration... Anyways I read through some previous threads, but couldn't find specific feedback. I don't track the car... It's my DD and will occasionally run the 1/4. Any help is appreciated
I have the GC too and just went back to the 600 \ 650 springs. I had the 500 \ 550 springs thinking it would make the car ride better but all I got was a sloppy ride. Rolling into the throttle coming out of the turns would make the back of the twitch instead of rotate.
I put the stiffer springs back in and raised the car about 1/2 and if feels fine now. It looked better slammed, but what I have now is a good compromise.
The rear dictates how low you can go since its not a strut or coilover setup
So you're saying the rear isn't really adjustable. Only the front? Cause I've seen some cars sitting slammed with GC kits. Ferny's car is low but I recall him saying he had to remove a perch or something to make it that low.
The rear comes down 1" with ground control, no lower unless you start modifying the mount even more than the instructions call for, with something like the mighty mouse kit. You can't really raise the height in the rear due to the short length of the springs, but a 1" drop will have no ill effect on anything so I can't imagine you would want it raise it back up.
I had no weight transfer issues at the drag strip with my 600/650 springs, the car hooked very well. I think the 600/650 rates are perfect and I wouldn't have wanted to go lower, but I don't drive it more than 3 to 4 days a week and it's not on bad roads when I do.
Pretty much
Yea I think it's more for picking your spring rates and adjustability rather than going slammed. It was on the car when I bought it, so I figure I'll get it to where I like it
That's true. A big advantage there in itself. I just like the slammed look and since it's my daily and I'm not tracking it, spring rate choice would be nice but not 100% needed in my case.
Btw, what wheels are u running? They look like polished accessory wheels in ur avatar but bigger. Lol
They look nice on there man. Knew that had to be what they were unless u had some CCW's or something.
Appreciate the heads up on the rear spring lowering amount with the GC kit. Would have been pissed if I sold my H&R's and ordered those to find out they won't even get as low as the springs alone. Lol
The stock shock's pressurized design is what limits the drop in the rear with the gc kit.. With qa1s you can slam it. The fe4 and fg2 reach a rested compression limit whereas the qa1 does not.
The fg2 will allow even less drop than a fe4 because it's much tighter. The mm kit ultimately raises the mount point of the shock allowing for even more drop with the gc kit and stock shocks, and is a much better option than removing the upper perch. I wouldn't remove that... although it seems in place I can't see what would hold the spring in place in the event the suspension was unexpectedly unloaded..
Oh, and by the way, if you're concerned with body lean, start with the Hotchkis sway bar kit. Don't bother with springs. Sway bars are the only way to reduce body lean. You could replace your springs with solid steel plates and it wouldn't help your lean issues a bit. Keep in mind that a stiffer sway bar will also make your car's response to common mode transients (i.e.: bumps you hit with both wheels at the same time) much faster and harsher.
Regardless of what you decide to do, I don't want to see this:
Sweet! Makes sense! I wouldnt want to remove perches or ruin the integrity of the kit. But... The custom ordered shorter springs seems like a great idea. And the MM kit would be used regardless to avoid any self leveling.
It's presently sitting in a box, collecting dust because it's absolutely unnecessary.
K-sports are unreliable, cost more than double what you'd be spending (you'd still have to buy end links), and are incompatible with aftermarket rear sway bars.
