That just happened........
#63
Also, I put a 160 degree t-stat in last night, and changed the oil. I checked my balancer bolt and it was a little loose!!! Not enough to cause any vibes or issues, but I had tightened the new OEM bolt to spec, and then to 140 degrees and everything by the book. That lil' bitch was loose, so I cranked on it again.
Make sure you check that **** after a balancer change!!
