Fu@kkkk!! Help please!
I'm in Waco, if you want to send me the board I'll fix it up for ya. Fix stuff like this at work all the time for guys. Have worked at micro level, replacing surface mount components with smaller foot prints.
Just last month replaced some led's in a steering wheel button board to change the color of the lighting emitted through the button.
T... I appreciate the offer as well!
Well guys, I paid $35 to have it fixed today. Dropped it off at the computer repair shop at around 3:30 and picked it back up right as they closed at 6. They put a small wire in place of the broken wire on the board and soldered it in place and also supposedly soldered all the little points back in place too so it was ready to install. I got home, put it back together and plugged it all up and two of my dot buttons wouldn't work. GREAT!! Just paid someone to do a half *** job!!
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
So... I finally decided to give it a shot myself. I usually do everything on my own but when it comes to electrical things like this, I worry too much about messing it up when i know im probably more than capable of fixing it myself. Anyway, I got the fine tip soldering iron and with a magnifying glass and a tooth pick, i went one by one on the 20 little connections to see which ones were tight and which ones were loose. Found a few loose ones they missed and very carefully used the soldering iron to attach them in place like they should have been. Its a tedious job to keep the solder where u want it and away from the spots u don't considering how close all of the connections are to one another. Very easy to make it messy if you're not careful. I then went down the row checking everything with a tooth pick again and went ahead and touched up the solder connections until they all looks nice and clean (thanks to my OCD!!) and WAAA LAAA, IT WORKS PERFECT!!!
![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
I'm so relieved now that its working again and i have it installed back in the car with new faceplate, new lense on the screen, new buttons, etc. All looks brand new! WAAA HOOOO! lol
Thanks for the help fellas!!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Thanks fellas! And yeah... Aftermarket would definitely be nice but I really don't use the navi or anything as it is. And all the aftermarket dash kits look funky to me.
Exactly. I'd love to have an aftermarket double din and although the unit itself would be nicer than stock, it just looks weird. The stock unit is fit perfectly to the dash and it looks nice, classy and uniform (as long as the buttons aren't all chipped up but i replaced those already). lol I also didn't want to deal with losing all of the little system warnings and things you can adjust and disable on the stock unit.
#39
