That Just Happened Too (Maggie Version)....
This is what I have that should work for what you need
http://www.thunderracing.com/shop-by...d-Controllers/
The Pacesetter header install went flawlessly. Had no issues with header bolts or clearance. The wires weren't hard at all to get out with long pliers and leverage against the valve covers.
Coil Packs Removed
Passenger manifold removed
Both Manifolds removed
Coil Packs Removed
#34
CS is sending me out a new set. They did require a deposit or the original mounts. Ya suckas must have been scamming them. Also still waiting for my msd wires and plugs from Nasty Performance if those ever arrive.
#35
Had a crappy sleep last night because now I am kinda pissed that I may have to remove my headers to install these new motor mounts. Two steps forward three steps back....sigh.
#36
Don't get too bent outta shape. Every time you take those headers off it gets easier. I think I did it two or three times during my recent heads project while the car was on jack stands. The last time I put them back in I did it without anyone holding a primary while I started threads.
#40
Even so, you can barely see it when on the car so who cares. You are exactly right.....as long as it works (which it totally does) who cares what it looks like.
