That Just Happened Too (Maggie Version)....
#41
Yeah, wrapping definitely takes some patience, along with gloves and long sleeves. That stuff frays easily and leaves particles ALL over you. I think mine turned out pretty nicely. Some say wrapped headers are ugly, but I kinda like the look along with the heat protection.
#44
Well, since my motor mounts won't be here till tomorrow, I went ahead and did the wiper assembly mod and removed the front bumper cover. Going to take the bumper cover to a body shop and have it repainted.
#45
Put in the new motormounts from CS. They are much better quality than the old grey ones I had.
The old mounts were pretty bad. One was warped and the one pictured was warped and melting at the top.
#46
I'd also like to give a HUGE THANK YOU to forum member BRANLAND.
This dude sent me a new pinning kit, an unused programmer, and a magnavolt. For how much? FOR NOTHING but shipping!!
I don't plan on using the magnavolt, but if the next forum member installing a maggie needs one, I will pay it forward.
Thanks again BRANLAND!!
#48
Dang! First hiccup during the maggie install. The Magnacharger manual states to torque the coolant vent pipe bolts to 106 ft/lbs. Now I thought it was pretty high, yet went ahead and attempted since I wanted to follow the instructions precisely. Well, I ended up breaking the bolt into the block. Fortunately I was able to extract it with on damage to the threads, but now I need to get another bolt. Does anyone know where I can get this or what size and thread type I need to look for?
#50
I need to find out what size bolt is and thread before I can even consider finding it local. From reading past maggie installs it looks like these bolts were included in the maggie kits and everyone used their stock bolts.
#54
That's fine, they are just used to the valley cover and intake manifold don't have a metal to metal contact. you can always cut an oring out of thick enough rubber if you want to have one there.
#55
No. Is there a reason you didn't use the permatex high temp gasket maker stuff?
#56
Okay,
So I need a belt tensioner. What and where can I get a good one thats comparable to the one that comes with the maggie kit? I looked at Autozone, Oreily's, and Advanced Auto's sites and couldn't find anything heavy duty per se.
Also, I am trying to get the crank bolt off. How are you guys removing it without the crank turning?
#57
Okay,
I would order the belt tensioner from Magnuson. It's now much beefier and comes in an 8 rib, in case you ever go that route.
#58
Order the one for the LS3 from Magnuson... P/N 31-14-59-041... it's beefier than the LS6 tensioner. I ordered this along with my 2.6" pulley (which I have not installed yet)
