Alradco with maggie.
Anybody have this interference between the electrical wires and the welded on threaded hole? I dont think this is used can anyone confirm? i'd like to grind it down or off.
Started on this project last night.
Everything was going peachy until I found a screw that retains the A/C line on the side of the fan assembly and keeps the assembly from coming out easily.
Took me about 15 minutes and a right angle screwdriver to remove the POS.
It looks like it is a necessity to keep the line from rattling.
Anyone doing this, I recommend you replace the hoses also.
Well that wasn't fun.
Put the radiator in, then tried to install the fans.
Nope.
Put the radiator/fan assembly in.
Fight for about an hour and finally it goes in, not forcing anything.
Would it have been easier disconnecting the maggie intercooler?
I doubt it.
Suggestion: If you are doing this, put a piece of cardboard between the radiator and the A/C radiator when installing to keep from damaging fins.
The Alradco is almost 1/3 thicker then the OEM and there is almost NO ROOM left between the front of the motor and the fan assembly.
Nope.
I doubt it.
Nope.
I doubt it.
Nope.
I doubt it.
