Lets talk clutches!
#41
The diamond kit came with everything i needed. I love it! Pedal isn't heavy and it grabs like a champ. No chatter either which is a must IMO.
Thanks for the help on the tranny fluid. Who carries that redline stuff Fuzzy? Planning to do an oil and tranny fluid change today. Might change the diff fluid too but its not that old yet.
#42
Huh i must have got lucky about a month ago and bought one of his last set. The PVC bushings go in a different place though, those go at the end of the remote shifter support. where the brass bushing goes on the other end of the shifter. If he has access to a machine shop they shouldn't be too complicated to make (measure a few diameters and widths and you are good to go. You just need to be tight on the tolerances to get the benefit. I would look at how much play yours has and see if it is worth it, I don't think mine was really sloppy, but i had the bushings and the transmission out so I was going to put them in.
#43
Centerforce DFX (12") clutch, LS1 flywheel and LS7 Slave. 20K miles on clutch and still holding strong. Smooth like stock. I previously had this same kit in my Camaro and transfered it over to the V. The Camaro was making 500 rwhp and I was running 315 M/T drag radials. Its a highly overlooked clutch setup and is bullet-proof. Do not confuse this setup with their 11" DFX clutch. ITs entirely different.
#44
Yep. I know if I exceed my stock LS9 clutch then I am going with the mantic
http://www.camaro5.com/forums/showthread.php?t=150784
#45
Surprised nobody's warning about issues they've had with lightened flywheels... IE the 19lb RAM FW that's available with the LS7 kit from SD. No personal experience, but was advised by many NOT to bother with the lightened FW.
#46
Granted, you need to be much more aware about your throttle position during take-off, but that's going to be true of anything compared to the 50.1 lb dual-mass boat anchor that came with these cars.
#47
#48
I've had my 18lb in for a couple years now. I love it.
#49
Originally Posted by lollygagger8
If you don't have a lightweight FW, or never driven a V with one, then don't send warnings on something you are actually missing out on. The revs/decels are waaaayyyy faster.
#50
LS9x clutch from katech has a 12lb flywheel if I'm remembering correctly. Runs like a champ on an unmodified V. I know because this was my first mod when I picked up this car...It being a twin disk clutch helps, smooth as can be.
#51
Eeeeaaaasyyy buddy. I didn't say nor indicate that I had first hand experience. I've done a fair amount of research though. I also had a very informative phone conversation with one of the vendors here who sells and installs a lot of ls7 clutch kits. His advice warned of many issues enherent with the lightened flywheel being ran on otherwise un/lightly modified V1's. Tunes, Maggies, cams, etc. change things - but that's not what I was referring to.
#52
Fuzzy; are you not modded fairly significantly? And tuned as well?
I'm not arguing one way or the other. I'm just playing devils advocate since most of the feedback here seems to go one way. A phobe call to East Coast Performance is where I'd send anyone who wants more info on this. Seems to me that they sell a LOT of these things, and install a fair amount too.
#53
#54
I'm in no place to "educate" on this. All I'm saying here is that I was advised against a lightened FW like the 19Lb RAM. And I was advised by someone that I would consider a pretty reliable source given his experience. If you want details and can't make the call, PM him. He's on the forum. My conversation with him was a year ago or more, so I wouldn't want to start quoting what he told me.
#55
Well to add some actual experience with the ram 19lb flywheel on an stock engine otherwise, it works great! if i didn't tell you it was a lightweight flywheel I don't think you would know until you punched it and felt the extra acceleration. It does not have any problems starting on the street, and really feels like stock in those terms, it just helps the car to be peppier.
I wouldn't hesitate to recommend the lightened flywheel to anyone, even if you want stock drive ability.
#57
#59
I've got a McLeod RST twin disc on a lightweight chromoly flywheel. Great clutch! It has about the same pedal effort as stock, just a little bit of twin disc chatter. I got mine for about $550 IIRC because of a pricing error. Flywheel was like $200 or something along those lines. I needed a slave cylinder spacer like the LS7 clutch.
#60
I don't even want to here about the light flywheel issues. My LS7 setup used a 13lbs flywheel and TOTAL clutch weight from my Exedy was less than 40lbs with a moment of inertia much closer than anything else listed in this thread and I never had an issue starting in traffic with either clutch. The Exedy is so light that the car almost revd like a bike. There is NO issue going to a light flywheel unless this is your first car with a manual transmission and you're a woman or a little sissy guy.
