Slave Cylinder???
Slave Cylinder???
Had the car in gear and when I started it, with the clutch pushed in it rolled front, I put the car in neutral now it won't go into any gear. I'm thinking it's the slave. How can I find out and is it hard to replace? thanks.
What does the pedal feel like? What happens when you start it in gear with the clutch depressed? Is there any drag? If this is more your problem, this will be a slave/master issue and bleeding the system may be all that you need.
If you can slip the clutch and clearly feel the engagement/disengagement points, I would look to the fluid in the trans, the linkage, or an internal problem
Let us know what you find...lots of threads on this exact problem recently.
