Looking at a '04 CTS-V ... any known problems?
...besides the typical axle grenade?
I drove the car and looked it over as well as I could without actually taking things apart, and it seems solid minus some brutally obvious things like a set of bald tires.
It's getting a GM 25-point inspection and a compression test now. Should I have them check out anything else, while I have my wallet open?
If it is leaking, don't go with an OEM one. I believe Alradco, and another company make aftermarket radiators that are all metal.
As far as cost, I have no idea. I do all my own work, so I'm not sure.
Good luck.
Good luck.
Besides leaking tanks, anything else that's a common problem?
Check ...
Check...
Got it ...
THIS PISSES ME OFF MORE THAN IT SHOULD BUT SERIOUSLY GM, SERIOUSLY.
My '04 2500HD, my '05 Cobalt and my '03 2500HD had peeling buttons. It's almost as if it's a trademark for GM vehicles anymore.
Check...
Got it ...
I don't know if you can check this but the tpms sensors go bad quite frequently in those. It freaked me the hell out the first time I thought I had a flat with no spare
THIS, and seriously tpms is the biggest load of **** system ever, whatever engineer created it should be tarred and feathered and then some. Wheel speed sensors on the hubs as well.
here are some common things i would check. so i could knock down the price.
Condensation i reverse lights, will lead to water in the trunk-- easy fix
Obv, diff whine at 40-50 mph, pinion lash in and out of gears,
radiator leak around the crimps on the top right side of the rad
Crazy oil temp reading-- bad ground for the sensor on the gas hood strut
reverse lock out weak
broken heated seats
water from the sunroof staining headliner- easy fix- clogged sunroof drain
gold front calipers?- road racing or indent on the headliner from a helmet
how bad does the motor shudder on shut off? dieseling-- motor mounts/ flywheel
chatter at idle = fly wheel is coming apart-- wont leave you stranded but sounds like ****
stability control warning after speed bumps
broken heated seats
Thanks for the feedback guys! The car came back with some issues I expected at 100k and 8 years old, but for the most part it was solid.
I am now the owner of a '04 CTS-V. Feels good, man. Already ordered the Creative Steel bushing and block, and 4 new BFG Comp-2's in OE size.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
