Catch Can
#42
CTS-V Shifter Sales
GZ Motorsports vacuum pump works awesome. I made a junction block to take air from both valve covers. It also holds the pressure relief valve so I don't have to use the huge ***** oil fill cap. I painted it black and its hidden by the firewall.
![](http://i1125.photobucket.com/albums/l586/bruckde/644a8ef7.jpg)
![](http://i1125.photobucket.com/albums/l586/bruckde/73302344.jpg)
![](http://i1125.photobucket.com/albums/l586/bruckde/d5d91fd1.jpg)
#46
#50
#51
Some of the pictures and instructions are confusing--the plethora of inlet/outlet options don't help things either. To wit:
![](http://www.andersonperformance.net/DSCN4836ww.jpg)
#54
#55
So, if I only have one inlet and one outlet, would you say:
1. Run the valley cover outlet into the inlet of the catch can
2. Run the outlet of the catch can into the valve cover outlet?
Normally, the valley cover outlet was attached to the cold air intake tube.
#57
Elite Engineering's directions advise this approach. https://store-581ad.mybigcommerce.co...nstall_LS3.pdf
#58
I would say it's up to you really, what you're doing has value but I'm under the impression that the general consensus is that the majority of the oil in the intake comes from the valley cover. If you wish to use the catch can to catch this oil you will want to run the valley cover into the inlet of the catch can and the outlet of the catch can back to the intake manifold. You will then want to run the valve cover inlet back to the intake tube.
I just ran outside to check my setup--when I did the installation three years ago, I hooked it up wrong. At least it explains why there's been zero oil in the catch can all this time. Oh, what a dumbass I am.
![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
