anyone have definitive info on LED bulbs?
I'm looking to do interior LED bulbs, and reverse lights. I'm reading up on superbrightled's, but do not want to order the wrong things.
http://www.superbrightleds.com/cat/l...s-/10-429-52-/
Anyone have any legit info?
With the info I'm getting so far, from my own research, although I'm not sure it's credible...
2 3157 Bulbs -Backup Lights
2 3157 Bulbs - Brake Lights (red)
2 561 Bulbs - Step lights
2 194 Bulbs - Map Lights (sunroof controller area), License plate
DISREGARD ABOVE FOR NOW leaving in case i have to edit
This has all the bulbs in the car
https://www.sylvania.com/en-us/appli...el=616&make=17
I've used the led's from ddm tuning too,pretty good.
Most of what I said before has been overcome by events, due to the weird fluxes in the eBay market. Basically, suffice it to say that you can always find great deals on LEDs directly from Asia as long as you know what to look for.
When in doubt, go with the guy that provides technical data on his design. You really want to stick with the sellers that advertise their products in terms of lumens, wattage, and color temperature. Here's an example of a set of 3157s that I'm interested in trying out:
http://www.ebay.com/itm/2x-CANBUS-ER...item4607e5b4f1
Each one of the five Cree T25 SMD LEDs in that package consumes 5 watts. They're solid parts. If that guy's ugly little 3157 package actually puts out 535-570 lumens, it should blow the living crap out of everything I've bought before. Once I'm done with my current mods and have more money to spent on little stuff like this, I'll buy a set and let you know how they fared.
all the anwsers are in here:
http://www.cadillacforums.com/forums...pics-name.html
what happens if you *** it up:
http://www.cadillacforums.com/forums...r-led-mod.html
IMPORTANT:
So you don't blow any fuses, make sure that you get the TYPE CK style LED
http://autolumination.com/3157_led_s...eshooting.html
IMPORTANT:
I followed one of those threads and did all my interior LEDs. Spent about $100 between superbriteleds and autolumination maybe even vled. Got some 54 led for the reverse lights from eBay. Nice and bright but now some of the LEDs flicker. Cheap china LEDs on eBay WTH?
LEDs don't flicker--even bad or failing ones. Loose electrical connections cause flicker. Check your connections.
