Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
HELP think my block is taking a sh!t
Old 10-21-2012, 01:10 PM
FknBoss's Avatar
You need a mass air flow. Its running lean you maybe detonating hopefully that didn't do any damage. Your prolly using oil because when the computer gets a lean code it full fuel. This can "wash the walls" is like brake cleaning rotors. Fuel takes all the oil off the cylinder wall and things the oil and the rings actually polish the wall.. never good. I can def see the headers are leaking I'd get that welded.. it maybe louder at the leak because the car richened up. Try unplugging the mass air and take it for a drive and see what it does
Old 10-21-2012, 01:11 PM
kl2onik's Avatar
im just surprised you guys think the leak could cause it to be so loud...would love this to be the case but im preparing myself for worst scenario(((
Old 10-21-2012, 01:23 PM
FknBoss's Avatar
Well I have heard leaking headers extremely loud. Its best to start simple before ripping apart an engine. On of the techs at work was working on an xk8 and he's pulling intake Mani to get to the knock sensor. I walked over and asked him why he said well its throwing a knock code. I said OK so you year it apart already? I go inside and its pegged on e. I said is there gas in it. Well it starts told him to ho over to shell put the best gas in take it for a drive he did and fixed. Who'd a thought a car running out of gas would throw a knock code?? Gotta start at the beginning..
Old 10-21-2012, 01:25 PM
FknBoss's Avatar
I'm worried it may need a fuel pump. That's why I want you to disconnect the mass air and see what it does.
Old 10-21-2012, 03:07 PM
wcryan's Avatar
Old 10-21-2012, 03:27 PM
FknBoss's Avatar
Yours doesn't sound too bad. Sounds like lifter. Possibly pre load isn't correct?
Old 10-21-2012, 03:50 PM
RADEoN's Avatar
I think it's a collapsed lifter, as well.
Old 10-22-2012, 11:43 PM
jrane's Avatar
^^^ I agree with the 2 post above me it's most likely the lifter being that the pre-load was off and caused a lifter to fail, along with what sounds like a decent exhaust leak from the headers.
Old 10-23-2012, 02:14 AM
odthetruth's Avatar
Originally Posted by kl2onik
here is another video and a pic of the trouble codes
http://www.youtube.com/watch?v=BMy_p...ature=youtu.be
The headers have been leaking since day one but was tuned with them present.
Check your hoses, and clean your MAF sensor, and make sure there's no leaks. Did you also just put a cone filter on, or are you still on stock airbox? I think your sound may be a lifter, but I don't think the code is.
Old 10-23-2012, 12:18 PM
9t8z28's Avatar
You hook up a vacuum gauge yet? Quick and easy
Quick Reply: HELP think my block is taking a sh!t
