LS2 Pulley Squeak -- Need help determining which accessory (video)
I had the exact same issue...typically did it when it was cold or after a cold rain. I put WD40 on the pulley tensioner arm. Sounds retarded but it worked right away for me.
Circling back since I hate finding unresolved threads when researching issues...
I replaced the alternator this weekend (from the top, with a 15mm socket and a lot of patience) and that seems to have been the main source of my issue. The last few days before I swapped it I started to notice a slight burning smell after I'd hop out of the car following a long drive. I started watching the voltage and while still adequate to keep the battery charged, was completely unstable. It would jump from 14.6 to 13 back to 14 etc so i figured something was up. Once I got the old unit out you could tell the bearings were shot at a minimum...no telling what else was wrong in there.
That being said, now I notice a much quieter sqeak from the A/C side of the motor...I dunno if its the belt or something else. I guess the really noisy alternator covered this sound up so I'll tackle it in a week or two when i have a free weekend.
My car was a CPO car and one of the service advisers kept going overboard when fixing issues on it before the warranty went out (I sure wasn't going to stop him). The A/C unit/belt and main tensioner are now the only accessory pieces with more than 12k miles on the front of the motor so I'm thinking one of those has to be what I'm hearing. I've been watching the factory balancer for wobble and it 'could' be suspect but it's only 6 or 7k miles old and doesn't appear to be separating so I doubt that's it...
you might want to consider a Good Year Serpentine belt.
These belts are lighter, thinner, and more flexible. Therefore, they generate less heat into the pulleys --->bearings.
And yes, if you squirt WD40 on the belt/tensioner and the sqeak stops,
then the belt/tesioner is "on the way out"
Gentlemen - I recently purchased an '06 V with around 42k miles on it. I'm experiencing the exact same issues as far as squealing/noise goes as discussed in this forum. It's typically nonexistent at lower RPMs/temp, but becomes much more pronounced once the car warms up and/or higher RPM levels.
I'm wondering if you ever came to a final conclusion as to what may have been causing the noise? I've already hit the belt with some WD40 to see if it quieted any, so am assuming it's one of the pulleys at this point. Noise seems to be stemming from the water pump area, but still kind of shooting in the dark.
Any thoughts/input on how to proceed is greatly appreciated. Thanks!!
WD40 / Belt dressing makes squeals worse. Check each pulley one by one but most importantly the harmonic balancer.
I'll report back once I find it.
Dealer swapped it when it was in for warranty work right before the extended warranty expired...If I remember correctly it's supposed to be torqued to some crazy number, right? I want to make sure I have the proper tools to check it.
Figured I'd revive an old thread to share my experience instead of create a new one.
Been battling with a belt squeak off and on for the past month and a half....
New Power Steering Pump (Spraying everywhere) - October
New Water Pump (Bearing went out) - November
Squeal starts, try screwdriver trick etc. can't find source. Pull off accessory belt and squeal stops.
New Idler Pulley - April
Swapped OEM Tensioner with a known working one - April
New accessory belt - April
Squeal goes away for a couple weeks, comes back. Pull belt again and stops...spin alternator by hand and it sounds like its making a small squeak at slow speeds. Plus voltage was a little sporadic.
New Alternator - Last Weekend
No Change, still squealing like a stuck hog...
Pull accessory belt off lastnight, start car up and still squeaking.
New Billet Tensioner - Lastnight
Today: Picked up an AC tensioner this morning to install tonight along with a new ATI balancer that I ordered earlier this week. I was going to wait until the weekend, but on my 65mile drive to work, I was about 2 miles out and let er eat in 2nd gear and it ate an entire rib off the belt....
At this point I'm thinking the harmonic balancer is the issue...I guess I'll find out when I get the new ATI and AC tensioner put in. The belt still has 4 ribs left, hoping I can limp it home tonight....Any insight on why it could've ate up the belt is appreciated.
A few pics for enjoyment.
#33
#34
His harmonic balancer is coming off the crank. He's right to replace it. The balancer is now to the point that the inside of the belt is riding on the lip of the pulley.
You argued that the routing is different between the LS6 and LS2 cts-v. This isn't the truth.
The image is of an ls2.
#35
Could be that as well , but best to check the routing on the belt ,if it's run wrong it will do same thing
#37
A belt can be run wrong though and cause it worth a quick check but yea looking at the second pic belt is correct
#38
That's fair input to make, as I had run the previous belt the wrong way temporarily....It quickly let me know as it burned against the alternator bolt...So yes, its very easy to do however, the belt was/is routed correctly.
Got the balancer off in a jiffy, however did not realize how deep the threads actually are in the crank. Can't get the pulley installer to thread in so I guess its off to the hardware store at 7am to grab a longer M16X2.0 bolt to pull the balancer in. Not the way I wanted to do it but looks like it will be the only way.
#40
I got the 33 piece puller/installer kit form advance.
I picked up a piece of M16x2.0 all-thread this morning, couple washers, a nut, and the bearing thing that came with the pulley kit...screwed it into the crank and then tightened the nut down with the washers and it slid right in.
No more squeaks, and vibration around 2k is gone. Didn't really notice any performance gain with the 10% UD though. Voltage reading 13.9-14.2 when the car is running.
