Negative camber in rear wheels
Getting tired of wearing out my drag radials on the inside edge. When I had it aligned last time I had them try to take out all negative camber, But they couldn't get it all out. They said I could extend the slots in the frame to get the rest out . I know it would extend life of tires & probably help traction, Which I need desparately.
So, I'd like to know if anyone has extended the slots in the frame to get the rear wheels flat & how'd it work out ?
Skydiver, do you have a feather-like wear pattern across your tread? This is characteristic of excessive toe settings.
Bad:
![](http://images.carparts.com/design/assets/classroom/images/align_t_toe.gif)
Excessive toe settings have other, inadvertent side effects such as toe thumb:
Bad:
![](http://datalocker.files.wordpress.com/2009/06/megan.jpg)
I feel you skydiver. I just bought new tires and at $1k + I really dont want them to wear out from a bad alignment. I am having them get my toe good and hopefully that will reduce the wear. The tires on the stock wheels were really worn on the inner shoulder only so hopefully it was alignment and not camber.
Does not show signs of excessive toe & you can still see the negative camber even though he took all possible out .
Been awhile since I had it aligned & can't remember the alignment specs right now , But I have a really good alignment guy that's into racing
He got all there is on camber adjustment
M/T drag radials only last about 1800 miles & that's with very few burn outs , of course the spool dif doesn't help since it scoots around every corner
Some times I've been having the tires swapped to get the outside edge to the inside & try and get some more miles outa them
Pull my alignment paperwork & the Camber is -- -0.8
Toe in is -- -0.08
Said that all he could get it out of the negative & said something about I
Could enlarge the slots to get it to zero , But made no mention of him
Doing it , Figured there must have been a reason he didn't offer to do it .
But at that time I was out to see if it helped tire wear with what he did before deciding if I needed to go further & it did help some but not enough
Just wondering if anyone has done this & how difficult it was , Shouldn't need much to get it from -0.8 to 0
That's not much camber or toe. I'm guessing that the spool is definitely not helping, and the obviously soft nature of the DRs. Maybe trying a bit less toe in would help? I don't know enough about drag racing RWD IRS cars and how much toe one needs to keep the tires square when you launch hard.
Are you looking for additional camber to assist with keeping the contact patch square to the pavement when launching? You'd probably be looking at +1.2 - +1.4 camber to do so, if I were to guess. Grinding the eccentric slots is the only way you will be able to do this.
-0.8 camber should not be a factor for tire wear at all, esp in the rear.
I slot the front K-Member on a F-Cars to gain more negative camber and there are no adverse effects from it.
Too much, though, and I begin running out of threads on the tie rod ends for toe adjustment.
1/4" slot enlargement is a lot.
As long as you have 100% fastner head engagement and the slotting process doesn't add excessive heat to the mount, I wouldn't think it would matter.
Skydiver, I did that to get my rear camber more positive when I installed my Pzeros and didn't want the inside edges wore out bf the rest of the tire. Wasn't that bad at all. What you will find is the lower control arm will contact the inside of the frame when you extend the slots and try to move the control arms toward the center of the car. I removed my LCA, cut the excessive meat off, then took some 3/16 plate and bent it around the arm and welded it up. I think that camber is where the tire is going to wear, and toe is how fast it's going to wear out.
Skydiver,
I also had my rear camber pulled out closer to 0, and all the tech at Firestone could get was -0.7 and -0.8. I have 5k miles on a set of BF Goodrich KDW TAs and have no adverse wear patterns.
Glad you made this thread... My Nitto 555's where dayum near dead on the inside of the tire, down to the metal...lol. I thought something was wrong...lol. I don't drive the V that much now for fear of killing new rubber on the back. CTS-Vette Eater how long did it take you to do that to your control arms?
