Engine Bay Paint Re-Styling
I did some painting of my intake manifold, throttle body and the plastic front cover that I thought I would share as it turned out fantastic.
The paint I used for this project was VHT wrinkle (also used on my valve covers, great stuff) and Duplicolor Red Metal Speck & standard gloss black.
Engine Cover Steps:
1. 3 coats for a base of the Red Metal Speck then allow to fully cure
2. Placed a vinyl Cadillac and LS6 decal down
3. Spray 3 coats of gloss black over decals and let fully cure
4. Remove decals to expose the red
5. 1 thin and 2 very thick coats of clear with quick spray times between each coat to created a cracked look and allow to fully cure
6. After drying I masked off the areas over the decal then sprayed 3 layers of VHT wrinkle paint. [\List]
Link to the LS6 Vinyl Decal I Used: http://www.ebay.com/itm/MG2012-LS6-P...e8000d&vxp=mtr
Results:
I also powder coated my calipers yellow, put black Brembo decals on the sprayed clear over which I will share in another post.
Engine Cover Steps:
Results:
