REVSHIFT Rear Cradle Busings
#261
If your removing the cradle, you should only have to disconnect one brake line. The pass caliper will just be unbolted and hung up. I just a use a vacuum line plug and put that on the brake line. You can buy those at any parts store. My cradle was out 2 weeks while I waited for my bushings, and it didn't leak.
#263
Just remove the pass side caliper, hang that up. You don't even need to unbolt the drivers side. The brake line for the drivers side disconnects on the pass side. You will understand when you look underneath. Pulling the cradle is the only way to go though. I had mine out in less then a half hour and that includes jacking it up and removing tires. Another trick I used that helped me out, has to do with the parking brake. Right underneath the drivers seat on the bottom of the car, that parking cable comes out. I pulled on the cable as hard as i could to get slack to work with, then I put on vise grip on it. The cable then had plenty of slack to be disconnected in the rear.
#264
you do not have have undo any calipers... just disconnect the brake lines on the chassis and the parking brake and theres 2 sensors that you have to disconnect should only take a few minutes then it will slide right out.
#266
I have to say, I've had a couple more weeks of driving on these bushings and I'm still loving them. They are a great solution to firm up the cradle and get rid of most if not all of the wheel hop issues...at least that was the case for mine.
#267
I wouldn't order from REVSHIFT!! I ORDERED MOTOR, TRANS, AND CONTROL ARM BUSHINGS 5 (five) WEEKS AGO FROM REVSHIFT ... STILL NO PARTS. They won't answer the phone and when they do its BS and never answer emails. last friday they finally answered the phone and gave me a shipping tracking number and it hasn't even been picked up for delivery. DON'T ORDER FROM THEM. I'll give you a update if I ever get my parts.
#268
Revshift can be a little slow. They only have 2 guys doing everything from answering phones to making the stuff. Everything is made in short runs because they make what, 3k V's a year? My trans bushing insert showed up in a week, diff bushing maybe a week and a half, and I just ordered motor mounts 2 weeks ago. I don't think anything you order from them would be needed right away anyway, I can wait a month or so for my parts. Not like I'm waiting on a starter.
