Hissing sound from front passenger wheel well
2006 CTS-V, 105k miles
After getting home from work and getting out of the car I heard a hissing noise coming from ONLY the front passenger wheel well. Sounded like the tire was releasing air. I walk back out an hour later and I can still hear the hissing, air sound, although not as loud. My tires are run flats so it is difficult to tell if theyve lost pressure unless you drive it and you can hear/feel the increased rolling resistance. However, car drives fine and id never think anything was wrong if i didnt hear this after turning the car off. Doesnt appear to be leaking coolant or anything and if it is, its so little that it isnt noticable. Could it be possible that a line/hose is loose? I could not hear anything at all when opening the hood and listening above the engine bay. I only hear it when I get down on the ground below/front of the car or up close right next to the passenger front wheel well. I literally have to put my ear to the tire to hear it. Any additional thoughts?
Update: After checking on it (keep in mind this is a few hours later), I took it for a quick spin to see if the temps or anything went up above normal, but all the operating temps stayed normal. However, my front drivers side tire showed 6 psi on the dash Tire Pressure monitor while all others were normal. Note that this is the drivers side tire, opposite of the one im hearing the hissing sound from. It didnt look/sound/feel like it had 6 psi at all. Felt normal. I will probably check in the morning with a hand gauge I have. WTF could be going on...between the hissing wheel well sound and the jumpy/incorrect tire pressure monitor? Let me know if I need to explain further. I should have cliff noted it line by line. Thanks
Could be the shock. I didnt see any leakage around the seals, but I guess I should physically test it out in the morning.
Why do you think the tire is fooked? As for the wild tire pressure monitor, what could create such an inconsistency that it would drop down to 6 psi (inaccurately)? I really dont think the tire is flat. Back a few months ago, I ran over a piece of metal one night on a bridge where construction was being done, and I KNEW that I had a flat by the sound/feel. Maybe I'm wrong, I dunno. But keep in mind the tire showing the low pressure is different than the one im hearing the hissing sound from...
Edit: Lol, sorry, I edited my original post a couple times.
My TPMS are also improperly set (frontend for back sensors etc). You have a flat tire.
I've always hated runflats... I was coming home from a 400 mile roadtrip, and about halfway home, my TPMS showed one tire at 0 psi. I didn't feel a difference, so I just assumed the TPMS was bad and kept going. I drove home and went to work the next day. It wasn't until I came home from work and decided to trouble shoot the TPMS that I realized there was no air in the tire.
I don't' currently drive on runflats anymore, but they were a great piece of mind.
Why do you think the tire is fooked? As for the wild tire pressure monitor, what could create such an inconsistency that it would drop down to 6 psi (inaccurately)? ... But keep in mind the tire showing the low pressure is different than the one im hearing the hissing sound from...
I've never had any issues with mine (well, other than when the dealership gave me 3 out of 4 that were apparently the wrong frequency and wouldn't sync with the car). I have 4 different sets of sensors in 4 sets of wheels, and had 2 other sets in wheels that I have since sold.
