How long did your long-tube install take?
About to put in some Kooks LTs and catted mids to hook up to my Magnaflow cat-back. Just wondering what kind of experiences y'all had while installing your exhausts. I want to know what to look out for, what to possibly expect. Thanks!
Took me about 3.5 hours with two guys which made it a lot easier, one to hold from the bottom and one to get the bolts on, the slowest part was getting the damn little clasp thingamajiggs on the Stage 8 locking bolts I used. Also had to disconnect the steering linkage on the drivers side, but not sure if that will be an issue with your Kooks.
Took me 5 or 6 hours with a friend and beer. We had to raise the motor a bit to get pass side in and raise the car as high as possible. But depends on which headers you have. Take your time... It's fun to get those stock dead weight manifolds out of there!
Yeah I have Kooks and Stage 8 locking bolts. It says in the instructions I will have to disconnect the steering linkage. I will most likely be by myself, in a paved driveway with the car on jackstands.
You'll have to dent the Kooks. Put the driver's side header in the car, mark the tube, pull it out, get a couple of thick towels to spread out the blow and give the tube a sharp rap through the towels.
The Magnaflow will not connect to the catted mids (are you using the Kooks 6760-FC?). You'll need someone with welding experience to cut down the Magnaflow and make it fit right.
Check to make sure you don't have any broken exhaust bolts first. Otherwise you'll probably get stuck in the process. My theory is that the inevitable broken motor mounts sheer the heads off of the weakest exhaust bolts at the rear.
Kooks 1 3/4 supposedly don't need a dent. The 1 7/8 headers are just too tight of a squeeze.
I backed the rear wheels up a pair of ramps and leveled it up with some jack stands up front. The catted connector pipes are designed to slip over the stock piping. Magnaflow's may vary slightly. I would still attempt the install and do my best to fit the pipes up, but not so much as to mangle a good weld job. Once you finish that up a little noisy drive to an exhaust shop shouldn't be too bad and they probably don't ding you too much in fab cost. It's really just two cuts and two full welds.
I also reused my stock exhaust bolts and gaskets without issue.
No dent in my 07 install with kooks 1 7/8. Ls2 had cs motor/trans mounts. Steering linkage was close but not touching. I did have passenger side rear bolt snapped. Took some time to get that out with vice grips. Removing stock plug wires biggest pits imo. Took me 6 hours over 2 days some of that with a buddy. First header install and took time to explore and address other maint stuff. Steering linkage is a pita to work with just doesn't want to move.
Yeah I'm using a 6760-FC. Kooks said it would fit right up. This will not make me happy. I'm surprised the header will need a dent, usually Kooks is the most flawless fit in the industry as far as I know. I think I will still try it myself though, the local speed shop said $400-600 for the install. As simple as headers are to install, it always surprises me how much can go wrong.
Karn's here in Groton CT finished up my installation for about $150.
Your motor mounts are probably going to need to be replaced too...while you're in there might as well replace them. Imo my new motor mounts made a overall bigger difference than the headers.
Just a tip on the stage 8 bolts, while pushing the clip on have someone hold a magnet next to the bolt so when they inevitably slip off while pushing down they don't fall into the abyss!
Little bit of work but they are well worth it in my opinion, no retorquing required after heating and cooling.
Got a late start today and only got the driver side in. It fit great, I didn't have to dent anything. Should have the passenger side in pretty quickly in the morning, then it'll be a really noisy drive to the exhaust shop. I'll be getting a Maggie in a while (hence the 1 7/8 longtubes) but til then I'll need a tune to drive around on. Who does mail order tunes for these things?
