Just placed my Revshift order
MM's, trans insert, diff bushing, cradle bushings, and trailing arm bushings.
I plan on starting off with installing the MM's and trans insert first, then driving the car for a few days to see if I can tell any difference's. Hoping it's easier shifting into 1st and R. Also be able to do away with the rough shut-down.
Then onto the diff, cradle, and trailing arm bushings. Hoping to get most of the wheel-hop out of the car and hopefully prolong my whining rear diff!!
i cant speak for your shifting issues but the second to turn the key and start your v for the first time you will notice a huge improvement with the aftermarket MM's ... as for the cradle bushings and trailing arm bushings have fun with that install lol but it does make a beautiful difference.
I just received the exact same order from them, but it will probably be a while before I can install them. How much are the cradle, diff, and trailing arm bushing suppose to help out with the wheel hop?
I'm very happy with my motor mounts. As other have said it is a huge difference when you start and shut down the car.
For the first gear and reverse issue I found switching trans fluid to Synchromesh fixed that issue for me. I know there are long debates about what fluid to use. I've tried Dex III, Mobile 1 and Synchromesh. Synchromesh gave me the best results out of the three.
TIA
So much for demand forecasting and market planning, I was hoping to have my ruca bushings sooner rather than later.
I placed my order on the 20th, and have yet to get any kind of shipping notification. I've called about 100 times and only gotten a hold of someone once. They told me it would be shipped over the weekend. Still no email, and couln't get anyone on the phone today.
