Coolant leak
I have to top off my coolant about every 2-3 days. When I was under the car I seen a little coolant on the very bottom of the radiator. I have heard a common issue is the water pump going bad. Is there anything else I should look for before I spend the $200 on a new water pump??
If you need to replace the radiator I would recommend talking to alradco on the other forum or Luke at Lindsay Cadillac for a Ron Davis.
Mine was $670 installed at the dealer (warranty @49K miles), so I didn't get to choose to go with the Alradco or Ron Davis. If you search around, leaking at the seams is a common issue on these cars. The stock radiator is about $300 (http://www.gmpartsdirect.com/results...umber=19259456) and an upgraded model will be closer to $500+. The radiator swap doesn't require hardly anything to be removed to get it out and the new one in.
I removed my underbody shield, rinsed the engine off, let it dry, then drove it for a few miles then jacked up the side so I could get my head under there enough to see where the fluid was coming from. It should be pretty easy to see if it's coming from a hose or the pump, since the upper and lower hoses are pretty far from the pump itself.
In my case, the coolant was appearing at the bottom of the radiator on both sides, some coolant was on the hose but it was evident that it was not coming from the hose itself and likely from the metal seams in the radiator. Any shop should be able to pressure test it to determine "what" is leaking if you want an opinion before you start buying parts.
mine leaked under the coolant return on the top of the radiator, had a crack 3ish inches long. I can have my radiator out in about 20ish minutes, requires really basic tools, all in all the whole job took about an hour. Dont pay someone to do it, its cake man. If you shop around you can get a stock radiator for as low as 130~ shipped. (This is the route I took as I dont plan on keeping the car much longer)
Agree with the others that it's probably the rad... common issue ....mine failed around 30k and was replaced under CPO warranty. Well, crappy dealer handed me a bottle of coolant and said the rad was on galactic backorder. I just topped off with distilled water and shelved the coolant.... waiting for the day when this rad pops.
Look up AlRadCo. I wouldn't even bother with OEM, if I was buying one.
