Rear Cradle Parking Brake
I'm about to drop the rear cradle again for revs gift bushings and new axles. Last time I dropped it I couldn't get the damn parking brake cable disconnected, it was too tight so I ended up working on the cradle under the car which made life not so fun seeing as i was on jack stands.
I do have the factory service manual but it was not help, anybody have any tips?
Disconnect it from the E-Brake pedal cable, close to where the trans crossmember is. Get under the car, pull the cable down, take a small pair of vice grips and clamp the pedal end of the cable where it passes through to the underneath of the car (to hold it out, keeping it from returning into the car). Now that the cable has plenty of slack, just disconnect the cable from the union.
Too much crap out at the rear...plenty of room where the pedal cable attaches to the cable going out back.
LOL parking brake cable TO TIGHT?!?! never heard that before
damn wish i knew that before i did my install. what a PITA to get the cable back on.
Why un hook the cable? I had the whole hub dissconnected (easy enough) and let it dangle/sit on the floor. It will not hurt that cable...and you will not have to deal with taking it off. Also if you plan on dropping it very low you will have to dissconnect the brake lines as well and I'm not sure thats a project you would like to get involved in.
Also doing axles so it's easiest to drop the whole cradle and pull it to another part of my shop where I can disassemble remove then reassemble and install axles, diff, cradle, trailing arm & control arm bushings with lots of room to work.
If I didn't drop the tank, I never would have disconnected the cable. Although, if you need to separate the cradle from the body completely, the union at the E-Brake pedal is the best way to go.
Not necessarily if you're just doing bushings and don't mind working under the car, but like DMM said working said no lift = PITA! Also dropping the cradle is not difficult, exhaust, e-brake cable and one brake line (which will require you to bleed the whole system).
