Problems setting up Nick Williams TB
IIRC, Jessie (Wait4Me) changed the PCM/TAC settings in the PCM at the binary levels that we don't have access to in regular tuning software to make it somewhat work, although I don't it was easy or a complete fix. Obviously too much to justify doing this instead of using the correct throttle body...otherwise he'd sell the patch tune a make a mint.
I have to help clarify. I have a 09 ls 7 TB. The OE LS 6 works fine. I have a harness adapter that was purchased with the NW 102. This is still the LS 6 Computer. I don't want to use the LS 7 TB I though I would be able to determine do I have a problem with the TB or the harness. I don't have the pinout on the harness to check. 70SS said he would send. I don't have an LS2 unit to compare. I was going to send to Nick but want to now check the harness adapter to see if that is the problem. Hinson Super Cars where I purchased promised to work with my tuner, but this is getting old. Its taken 3 weeks of no movement so far. I m sure theyll get it. But Im itching to melt some rubber.
Ya know it needs to be tuned to handle that much. Patience on pressing the button. I am working on a fab for a Vette (C3) rear end with some mods to handle the power. I will not be posting a pic of a exploding diff if I can help it.
AWESOME! I am glad to have helped, without these forums this stuff would be impossible. In "The good old days" you found some old guy or bought a couple of books and dug in. Today everything is so much more complicated that we couldn't hope to do this stuff ourselves if not for the vast resources available on the internet.
