Motor Mounts - Ridiculous interior vibrations
My 2007 V has the yellow UUC motor mounts installed. The vibrations generated while driving the car are absolutely horrible, to the point where it's rattling the interior plastics at certain RPM levels.
Does anyone have a recommendation for a motor mount that DOESN'T do this? I'm fine with and understand the added vibes from poly-based mounts. But I cannot hear my exhaust with the windows up because of the vibrations. Does anyone else have this problem? I figured a H/C/I car with a Corsa exhaust should make some noise, but you wouldn't know it if you were driving around in my car with the windows up.
I'm at the point where I'm ready to go back to the stockers regardless of the premature failures. I also have a CS transmount. The rear was recently replaced under warranty so the OEM rubber diff bushing is currently on duty. I have no plans to replace the diff bushing until it's shot.
Thanks everyone; I'm just really frustrated with the car at the moment and would like this fixed ASAP. I appreciate all comments, especially from those who have gone from these UCCs to something else.
If I don't go back to OEM, I am considering Revshift's blue motor mounts.
I'm thinking that something else is the culprit and the motor mounts are just transferring this through the car. I have umi motor mounts (way more solid) and do not have any bad vibes. Check to see if you're balancer is wobbling.
Thanks very much. Will check a little later today and report back.
If this is not the issue please give us some more details. Is it dependent on vehicle speed or engine speed? IF its vehicle speed is it only at one speed (what speed)? If engine speed, does pushing in the clutch make the vibrations go away or no? the more information you can provide the better.
It's probably the worst at low-moderate throttle input, merging onto a highway in 5th gear.
Haven't left my office yet to check, but I can tell you that it's certainly engine RPM specific, actually probably more like load specific. Driving around town or merging onto a highway makes the vibes shake the interior plastics. However, if I'm crusing at 75mph (so just north of 2000rpm) on a flat road, it's quieter. But the minute I get on the gas, the vibes start.
Just got back from taking a look. The balancer spins true. I did a few searches here and on the other forum for videos to make sure I knew what I was looking for. And the balancer has no visible signs of wobble.
Secondly, I placed the car in neutral and revved it. No vibrations were transferred - interior panels didn't rattle. Placed the car in 1st gear, clutch disengaged, and revved several times to 4000-4500. Once again, no vibrations were transferred through the interior of the car. Plastic panels didn't rattle.
Frankly I'm a little bummed because I was hoping it would've been the harmonic balancer.
Fuzzy, the UUC mounts were already on the car when I purchased it. Even during the test drive, I felt the interior noise vibrations were very un-Caddy like. The car came to me unmodified except for those mounts.
I later did the trans mount because shifting the bugger into reverse was virtually impossible. I haven't really noticed any increase in the intensity of the vibrations since doing the CS trans mount however.
If you have the dual mass flywheel, Dactari is right. The stock clutch is so horrible that I forget that some people haven't replaced it. It was the first thing I did (at 6k miles).
Yet another UUC motor mount user chiming in with no such vibration issues.
Any way for him to confirm that it's a bad flywheel? I guess if the balancer is OK there's really not much else it could be other than the flywheel/clutch combo.
Thanks, guys, I appreciate everyone's help with this. It is the stock clutch, but luckily, I have a brand new LS7 clutch kit that arrived late last week for install.
I will try to make arrangements to have it installed ASAP. In the meantime, I never would've guessed my flywheel is causing all this trouble.
Will let you all know how it turns out.
I would inspect your driveshaft and all driveline components while you are under there as well to make sure nothing under there could be suspect.
If the vibrations go away at idle while revving it that would lead to a drivetrain component causing the issue.
The mounts are still connected to the engine at idle so these vibrations would light up as soon as you rev in idle.
The flywheel is also attached to the motor and should exhibit the issue while revving in neutral.
You're driveshaft is probably the culprit. The carrier bearing isolators/rubber section is well known to fail. See if there is anything even left in that space. Some people have taken pics of their DS's and it just shows a shaft riding on the bottom of the bracket with no isolation material in between the bearing and the bracket.
While applying a load you are probably deflecting the CV joint a bit which would increase the vibration over just a constant speed.
Take a look and let us know what you find.
