Best place to locate IAT sensor? Also, best drag tire for stock rim?
So I want to relocate my IAT and just do not know where the best location would be? Near the filter? or closer to the intake? In the intake pipe? or actually in the intake (front of Fast 90 where the removable EGR hole is)?
Then, I just bought an extra set of rims that will be strictly for drag tires and just wanted to grab some opinions on tires? The will have to be able to go over the road as I do not plan on taking tires on and off at the strip. Thanks!
The reason why you want to put the sensor in the airbox, regardless of whether you choose to go the Omega thermistor route, is to get the sensor away from the radiator. Less heatsoak --> more accurate IAT readings in stop and go traffic.
https://ls1tech.com/forums/16592376-post14.html
Just get the three things on the linked list I provided. The sensor is the second item. $22 and change.
The rest of the kit is just plug and play. You'll probably want some tie wraps to make your routing look clean. That harness comes with a lot of unnecessary slack.
319$ a piece
any suggestions for a little cheaper version?
Also, Fuzzy I see you loacted the IAT right next to the intake pipe in the filter. I plan on mounting mine on the other side in the middle of the filter (directly accross from the intake pipe). Any thoughts?
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Nothing other than that you might have to get creative with your cable routing to ensure you have enough cable length to reach that far. Might also make it harder to remove the filter if you don't have a lot of slack.
Is it the IAT sensor that gets heatsoaked or is the whole intake? It seems to me that moving the IAT sensor further away from the TB and intake manifold would be tricking the ECU to think theres cooler air coming than there actually is if the whole intake pipe gets heatsoaked. Does a retune need to be done? If this mod works with success it's something I wouldn't mind doing, but I don't want to hurt the engine any for a couple extra ponies.
I disagree.
the point is to give the proper IAT to the ECM. This allows good tuning of the VE / Virtual tables for calculating fuel.
There should be no reason one wants to 'trick' the ECM into colder air, or more air. Its not beneficial, and a tuner will just end up skewing the values to compensate for 'that day' hotter air being ingested when the sensor reasds x.x° cooler. One has then just introduced 'error' into the tables, as you started with error in your data (the delta of air temp). Its actually no different than heat soaked, but just the other way...
Reason for relocating is to avoid 'improper' values used in calculating fueling and to get the most accurate, ideally the 'actual injected temp' The Omega sensor allows for quicker response as well.
Sensor placement ideally should be intake before throttle without head soak, this usually means relocating to front bumper or airbox for closer values. Unless you use the Hitachi slot (which is less prone to head soak)
However, if one uses Meth or dry nitrous, then this must be downstream to the injection point... usually closer to the throttle.
