04 CTS-V throwing codes running rough!!!!!
You hot the nail on the head. I got home and pulled the the valve covers and found a broken exhaust valve spring on cylinder 3. I am ordering a new set from texas speed tonight.
http://texas-speed.com/p-1383-ls6-va...od-to-550.aspx
Are they a good choice?
![](http://i220.photobucket.com/albums/dd278/jeremyd123456/image_zps2b842d55.jpg)
Thanks for the help.
Looks like your spring held up better than mine. I dropped a valve into the first cylinder and the engine is currently being replaced with ~25k mile LS6. Yeah those will work (Factory springs) but why not upgrade to a dual spring just in case and/or if you decide to put a bigger cam in it down the road. Glad I could help.
