automatic
I do know that it'll be much easier to run it on a manual valve body instead of tryin to get it wired in to the harness but that's definitely up to personal preference there. Minus a little tunnel clearance it shouldn't be to bad. The 80e and and t56 ate damn near the exact same length just a difference in diameter. I had planned on just bending up a new sheeetal dented console to fit in mine once thentunnelnis clearances enough. Good luck Greg let me know what they tell ya about it all. Maybe compare notes on the two builds
Im sure theres details in each idea i didnt present but nothing ever goes smooth with modded cars.
Either way relativley speaking im sure it can be done fairly easy i just have no idea how hacked up the cab will look trying to fit that auto trans in there. If i do it i want it to look factory.
That might be asking to much though.
I plan on throwing the 80E on the trans jack and see how far off it really is from fitting when I pull the trans for the clutch and rebuild. I'll be sure to take plenty of pics.
Greg - you're only a few minutes up the road from my shop...I'll give you a shout when I have this apart and you can come see for yourself. Just have to finish the cam and heads I started yesterday.
I know you had issues with RPM in DE but they were probably the best chance of doing a 4l80 swap in your car. They just did one in a 2012 Boss when everyone said it was impossible.__________________thanks man, but the shop I am gong to is not a vendor here but he has been around for over30 yrs. in Elkridge Md...With that info u should know who will be doing the fab work.....He is expensive but knows his stuff....If he does my V as a doner, will probably cost app 10-12 grand...that's tranny, converter, cage, 9'' four link or IRS...He wants to do the 4 link...and built 4L80E, shifter, and finished interior....
how u doing DMM.....I have a couple of good mechanics who want to pull my trany and check it and the Mcleod out..My installer, we think, ruined the pilot bearing trying to install the engine from up top....This has been 2yrs. ago..I drove to OC and had trouble getting reverse..Also too much vibration...I had about 20 dyno pulls on her....and driving it back from Keith's in Gettysburg..A few hundred miles later at my house I could not get any gears...2 weeks ago my friends bled the clutch, only took 40 mins, and now I got all my gears.. It shifts great but now at around 5,500 rpm it jumps out of 4th gear...The peddle feels great, shifts great but now I got a fourth gear problem.. It could be just the Pilot bushing..cause I am getting heavy vibs at high rpms..Hoping the input shaft is tight. and syncro is ok and it is just the pilot bearing
.I'll report later...thanks guys................
2004 Cadillac CTS
Trader Rating: 1
Don't think it's been done yet. I'm literally just gunna buy an 80e have it built. Then install with a sawzall. After its in ill fab up a nice stainless or aluminum center console wrap it innblack carpet and call it a day
I agree......Not to get off topic but how does one list like 6 quotes from a thread in 1 single post???? and add a response?? I have over a couple thousand posts and never knew how to do that....I copy and paste one's remarks and highlight it for now..thanks anyone..U can PM me
2004 Cadillac CTS
Trader Rating: 1
ps: maybe if I get mine out next week I can drive down and bring it up to my friends shop and we can take pics an do some estimating????
