Start up issue....
Start up issue....
ok, so ever since this recent build up, I have not been able to line up a start up issue. I start it up, and it starts stuttering, if I pump the gas a little bit and keep it above 1200 RPMs it'll stay going, and in less than a minute it lines itself out, and stops doing it....than it runs fine. If I dont pump on the gas than it'll stutter real bad, and bob between like 200 and 1200 RPM's. Sometimes it will die, sometimes it'll pull itself up, and run....
So last night, we were working on the tune, trying to get that issue lined out....We eventually realized the guy that had tuned it had done some rather strange things with the tune...that could explain the issue. So after working on it for the next couple hours, we thought everything was lined out...but went to start it the next day, and the stuttering is going again (it usually only happens with a cold start). So upon looking at it further, I notice my TPS sensor is off it shows 11% when my foot is completely off the throttle, so I was thinking that maybe causing the issue....but can't seem to get the TPS to "relearn" I did the whole, leave car in run for at least 3 min, turn car off, start it, leave running for 30 seconds, turn it off, and start it again, and its still wrong....
Any recommendations on getting the TPS corrected?
ya, we didn't notice the problem with the TPS till after we di some changes to the tune.........but i def think the original guy tried to tune around the issue, making everything look weird
Depending on what cam you have and what the base running airflow is set to, that is perfectly fine. I am just now starting to tune my cam+heads and I am at 10% TPS at idle (at 875 RPM target idle speed) as well...
That's why I said...post your tune, post your mods. There is a lot that can be misinterpreted in a tune. FYI - IIRC I was at 3% TPS with everything stock.
