Maggie problems
Maggie problems
Recently the V has been on dd duty while I finish my other car up. Over the past few weeks it has just felt kind of unresponsive and has a very bad off-idle stumble when its cold and sometimes when its hot.
Backtracking a few weeks, I was at my tuners shop and I fired my car up and he thought I had a vacuum leak. We poked around for a while with a can of brake clean and found nothing.
So yesterday given how poorly its running, I dug a little deeper and found that when i spray starting fluid or brake clean right under the snout at the base of the rotor case it bogs the engine down. Shouldn't the idle pick up?
Other things I have noticed are that before I put the LT's on it I could peak at 9.8 lbs of boost. After the LT's it maxed at about 8.4 which I understand is normal with the decrease in back pressure, but now ill be hard pressed to reach 6psi.
What type of gasket (if any) is used between the rotor case and base plate?
Anybody else have this problem?
Edit: It dynoed at 488.3 hp and (im not making this up) 488.3 tq. It would melt tire 1-3rd gears but now it just feels sluggish and hard starts sometimes
I called Magnusen today and they said the same thing, 510 locktite.
Yes, the engine is completely stock aside from the maggie and LT's. I dont tend to beat on it too hard and it literally just turned over 50k last week. No strange noises to speak of either aside from a slight whistle/intake hiss under light load.
Edit: Thanks DMM, I started looking at valve springs and thought "may as well do a cam at the same time".....great
http://www.ls1gto.com/forums/showthread.php?t=382840
Has some good info on bearings and stuff if you want to go that far into it.
I am offering these suggestions b/c your tuner probably has 20+ degrees of timing up top to get that kind of power which is not the best for longevity. Get your IAT's as low as possible and use meth to up the octane a little.
All I know about the timing is that it was at 15 and he told me that he pulled timing until he started seeing big drops in power.
Punishment, could you elaborate more on that bypass valve. Im standing in front of my car right now.
With the car off the valve should e closed. It's on the drivers side of the blower. It has one vac line running from it to the snout. It works off of vacuum. So with the engine idling it will pull the valve open and bypass the rotors. When u go into boost it closes tht valve and all the air gets compressed thru the rotors. So take a look at the valve with the engine off and make sure it's closing all the way. When u start the car it will open. Sometimes those valve rip the diaphragm's in them and give problems. Check there first and go over all the lines.. These Maggie's don't have many lines so you should find ur problem fairly easy but if its the actual Maggie leaking then u need a tear down
