Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Sleeper cam for V?
Old 07-02-2013, 11:59 PM
whitedevilWS6's Avatar
Default Sleeper cam for V?
I've been toying with the idea of throwing a super stealthy sleeper cam in my V. Of course, having a full exhaust system will only accentuate any slight lope, but it is what it is.
Who has had a good experience with a sleeper cam? How smooth was idle? Any added vibration?
Old 07-03-2013, 12:42 AM
itsslow98's Avatar
Contact a vendor and tell them what you want from the cam. There are definetly options out there that will gain solid power with little to no evidence sound wise. You can also do things in the tune to make it even less noticeable.
Personally I love cam lope and even more so coming from a cadillac.
Old 07-03-2013, 01:00 AM
CTS4 V's Avatar
nothing is more badass than pulling into a gas station with a cammin caddy
Old 07-03-2013, 01:12 AM
Yeah I totally get the concept of a cammin caddy. As it is people have to look two (or three) times just to make sure they heard right. But to me, it's a Cadillac, not a dragster, so it needs to retain its smooth character that the name implies (even though the V itself departs from that!)
Martin from Tick Performance advised me to go with the LS2 Street Heat Stage 1 cam (yes, you read that right.) 225/230 .61X/.60X 114+4.
Oh yeah, and I don't want people to know what hit 'em til they're sucking my exhaust, and I want them to be scratching their heads if they get the chance to stop with me afterwards. Some people have no idea what that V symbol means.
Old 07-03-2013, 01:20 AM
itsslow98's Avatar
That cam has no overlap so it should idle really smooth. Raise the idle rpm a little bit and i bet it sounds stock.
Old 07-03-2013, 09:40 AM
Eastern Regional Coordinator
CTSVBiggie's Avatar
I like the one I got from PatG/EPS but always wish I went bigger. Not too much lope.
Ignore the fat ****
Old 07-03-2013, 09:41 AM
CTSVBiggie's Avatar
oh and from memory its a 226/230 598/608 112+2 or 113+2
Old 07-03-2013, 10:02 AM
Yeah anyone who knows what they're hearing would know. Sounds good though.
Old 07-03-2013, 10:22 AM
CTSVBiggie's Avatar
Ive pulled in at a meet spot and had people saying its a fully built 10 second car. Im like baby cam and bolt ons and me not launching her... maybe 13.1... MAYBE.
Old 07-03-2013, 10:37 AM
DACTARI's Avatar
it's a 113+2. i remember cause pat g specced the same cam for me.
Old 07-03-2013, 10:40 AM
CTSVBiggie's Avatar
I like the cam. One major requirement for me is that it hold a decent idle even on a hot day with the AC cranking.
As is it gets a little extra lopy on and off throttle when its cold.
Saw a MS3 LS6 V the other day. Really not sure it would idle with AC on. But god it sounded good.
Old 07-03-2013, 12:07 PM
How's the vibration with a cam? I know even a stock car has a little shake but I want to minimize it.
Old 07-03-2013, 12:39 PM
CTSVBiggie's Avatar
there is some shake. I am still on stock engine mounts(no issue yet) but plan on going to stiffer mounts soon.
Old 07-03-2013, 01:10 PM
DACTARI's Avatar
There are two types of bothersome vibrations in a car-- buzzing (high frequency) and shaking (low frequency).
The vibrations that result from camming the car will be an interaction between the cam and the mounts. A more solid mount like the UMI will transfer almost all engine movement into the chassis, resulting in more shake. By contrast, a very soft mount like the stocker will have the engine jumping around in the engine bay like a popcorn maker, and this will feel like higher frequency vibrations in the car.
In my case, with the stock cam and UMI mounts, I had a fair amount of vibration at idle and low RPMs that would rattle the sunroof and one particular place in the dash. However, with the 228/236 111+3 cam, the high freq vibes are completely gone. Instead, the car gently rocks from side to side at idle.
My guess would be that if you are going with a low to no-overlap cam, then you would be more concerned with high frequency vibes. The best motor mounts for that situation would be revshift's softer poly mounts.
Old 07-03-2013, 01:48 PM
IdriveaV's Avatar
That actuallly sounds quiet, good and sleeper like if you ask me
Old 07-03-2013, 01:52 PM
CTSVBiggie's Avatar
its not too bad. Which was the point when I asked Pat what I should go with....
Old 07-03-2013, 06:16 PM
98cobra's Avatar
I have tuned vehicles with the torquer v3, and Lingenfelter gt-9. Both had great drivability.
Old 07-03-2013, 07:19 PM
DMM
DMM's Avatar
I would follow Martin's advice. If you were very clear on exactly what you were looking for he will not let you down. All of the Tick boy's are excellent people to deal with. They have a stellar rep for a reason.
Old 07-05-2013, 11:14 AM
Sales@Tick's Avatar
Thank you for the kind words.
The cam I recommended has zero degrees of overlap. It will be definitely be a sleeper for sure while making great power across the board.
It won't pump out Polluter or MS4/T-rex numbers, but it will be a solid driver.
Old 07-05-2013, 03:12 PM
Yeah Martin I had to hang up the other day, I was driving. Once I can find a shop to quote me for swapping my LS into my truck *hint hint* and I get it done, it'll be time for an intake and stealthy cam for the V! I can't wait!
Quick Reply: Sleeper cam for V?
