Just picked up an 04 Maggied V
I just picked up a 04 maggied V. The car has 60k miles. mod list goes as fallows:
Maggie Sc, (mp 112 I believe)
Corsa Exhaust (cat back) X pipe
I believe that the shifting is stock because it seems way to long. I want to look into getting a shorter throw system as iv read a lot about the UUC system which i think ill go with.
I really want to get out as much of the engine and current set up as i can. My question is what are my best options as far as going with Cam, Long tube headers / High flow cat combination, and i would also like to know some options as far as a bigger TB option such as going with something other than the stock TB on the blower... Maybe a 88 or 90 mm option if possible. Another thing i would love to hear some opinion on is what heads would be the best option for my current set up to get the best HP numbers.
Any info would be awesome guys.. If any of the FI guys could chime in i would really appreciate it!
Thanks, Keenan
Thanks, Keenan
Bought it From a guy that i knew back in michigan. Always indoor kept. He would keep it in his warehouse most of the time rarely driven as i knew him for a while. Wanted to pick up a new toy so i figured this was a good option as i know how well the car was kept.
A mild cam would be great on a Maggie car. Something that would be optimized for the blower with stock displacement. Not some huge naturally aspirated cam like an MS3. Longtubes will definitely provide hp/tq gains. Plus with the cam and headers, it will sound better in my opinion. A Cadillac with some exhaust lope gets strange looks sometimes..hah
To go with a 90mm TB you will need to change the blower snout to a 90mm (4 bolt style) as used on the 05-06 LS2 Maggie cars. Magnuson does sell these. I have been thinking about trying this on mine, but not sure if it's really worth it or not dollarwise.
i did some pulley swapping when changing my belt yesterday and some how found another lb of boost..it crept to 14 in the upper rpms and feels a bit more on point. ill make a small vid later today
90mm TB swap was dyno proven for about 6hp. From my experience the best way to get power out of these Maggie's is to setup the motor for max power NA then slap the 112 on it. Lowering compression and using a blower cam that bleeds off boost is the wrong approach to building this particular set up.
Set up the motor for max power N/A? Cause that would include high compression and a big cam with high overlap that will bleed boost.
I'd say the best way is to keep relatively high compression (needs less air in the cylinder to build boost) and a good blower cam with low overlap so as not to bleed boost. All good blower cams utilize a wider LSA to limit the overlap.
A good boost came would be something on a 115-117 LSA.
Sure, you can set it up N/A and slap a maggie on there, but it will be far from optimized. I do agree about maintaining a relatively high CR though.
take a look at what shops and cam companies recommend for the maggies..youll be surprised
they do keep the lsa in the upper teens but not that much higher than say a stock ls6 lsa.
im running the ls9 cam and chose it for the drivability aspect..not power. when i set my motor up i did so on a budget and with drivability and reliability being top priority...plus i have room to grow with just a set of head studs and bigger adder keeping me from big power.
