2006.what slave for LS7 CLUTCH
Installed a new LS7 clutch kit...and used an LS7 slave...seems logical, but if I remember correctly I must use an LS2 or LS1.Does that sound correct, cause after bleeding I am haveing trouble getting gears...With the new UCC bushings and the home depot fix with the engine off it goes into all gears really good......HELP
PS: 6.0 iron block or LS2 NOT 5.7
You need a LS7 slave because of its longer reach and larger diameter throw-out bearing. If you're having trouble finding gears, that means either a) you did not torque the pressure plate bolts to 48-52 ft-lbs on the final pass, b) you did not follow the star of david pattern, or c) you still have air in the clutch lines. My money is on a) because that's what most people have done. This is one of those scenarios where a torque wrench is not optional.
The best slave is still the PowerTorque CS2529, sold by O'Reilly.
I hope the answer is C....the pressure plate was torqued star of david , starting at 15lbs. then 35lbs.then finished with 52lbs.with blue locktite. Might have to get something like the PowerMotive setup, cause no more air is coming out. Every part is new. I sure hope I don't need a spacer. I need a Bud Light.. Back with u'all later.................
ps: calling Lindsay again today..With the holiday I didn't get a return call...
Ls7 clutch
Quote:
Originally Posted by 54inches
My vote is C.
I used a PowerMotive setup and got all of the air out
Greg..
The only way I have found to properly bleed any hydraulic clutch is to open the bleeder and have someone push the pedal with the bleeder open. The bleeder must be closed before the pedal bottoms out, however. Once you have a decent pedal, pump the pedal about 15 times and then repeat opening the bleeder and then pushing the pedal, closing the bleeder before the pedal bottoms.
Vacuum bleeders have never worked for me on any clutch system...ever.
Good luck buddy!
Good luck buddy!
fluid and clutch
V is just a grocery getter...and hell, I just wanna see some street time. 800 miles in 2 1/2yrs. doesn't get it...I ordered the Motive bleeder from Amazon. paid xtra for 2nd day delivery. so Friday, hopefully this LS7 clutch job will be done.plus, I can use it again after I destroy the lower tq. LS7 clutch.
Greg..
Good luck buddy!
Good luck buddy!
I bled mine manually with my LS7 setup and had no issue. I do have a Mity Vac but I doubt I'll use it for this. I forget which speedbleeder I have, I want to say its the East Coast Corvettes version and I did notch the bellhousing.
